Go to Post You can reduce the size of your wench. - ngreen [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 06-05-2004, 18:08
BillyGoats BillyGoats is offline
Paper Eater
None #0061 (Intimidators)
BillyGoats can only hope to improve
Send a message via AIM to BillyGoats
Re: Tank Treads
Originally Posted by Matt Reiland
We have used the Green/Blue Brecoflex the past 2 years and I doubt we will go with treads again next year.
Both years we have had a shifter with quite a bit of power, last year we shredded I believe 6-8 belts total mostly on the wire mesh area. In low it will spin them even up against a wall so there is a bunch of stress.
We found that it wasn't worth it for us to go with the solid core center since our tracks always ripped first at the edge inward. At the price of the solid centers you literally get twice as many with the serrated center. I have seen a bunch of new pneumatic tires that can easily provide the same amount of traction as the supergrip belts. I can bet that we will be a wheeled bot next year, probably 6 wheels that are 3-4" wide 6" diameter pneumatic. Also keep in mind the delivery on the Brecoflex is pretty terrible, usually at least 2 weeks and up to 4-5 sometimes.
If I was going to use them again I would look at the Gum Rubber and Red belt self centering.
If we where going to be around next year we would probily have a design simmilar to team 25's. 6 wheels like that.
The shipping we have never had a problem with tho. Always recive them within two weeks
Keep It Simple - Team 61's Motto
Any Thing on out Robot Can be Fixed in 5 Mins!
2005 Motorola Quality Award
2004 Battle Cry 5 @ WPI Eighth Finalists...4th Seed! 6-3 Record! Thx 237 & 830!
2004 Mayhem on the Merrimack Champions! 4th Seed! 9-2 Record! Thx 562 & 1289!
2004 Mayhem on the Merrimack Fastest Robot Award!
2004 Beantown Blitz Champions! 4th Seed! 11-1 Record! Thx 571 & 1100!
2004 National Semi Finalists
2004 Florida Regional Judges Award
2004 Florida Regional Champions! Thx 945 & 386!
Unread 06-05-2004, 18:16
Pat Roche Pat Roche is offline
Mechanical Engineer
FRC #0134 (Team Discovery)
Pat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to behold
Send a message via AIM to Pat Roche
Re: Tank Treads
Its listed somewhere in this thread. They're green-blue, probably the same ones matt mentioned. They costed us $200 a piece. Another reason why belts have a tendency to rip is the tension on them. You really need to find your happy medium with them. If theyre too tight theyll rip and youll lose traction. If theyre too loose theyre can bind or crease/rip and youll loose traction. You gotta find the happy medium with them.
-Pat
Team Discovery #134 Alumni 1999-2004
Division by Zero #229 Alumni 2004-2009
Team Discovery again?
2010 and Beyond
Where have the last 11 years have gone?
Swerve/crab drive and tank turning activemx Technical Discussion 9 23-02-2004 18:26
tank treads vs. threaded wheels lj8758 Technical Discussion 14 24-01-2003 00:30
Under or Over? To tank or Not to tank that tis the question! archiver 2001 2 23-06-2002 22:53
TANK TREADS...welp. archiver 2001 13 23-06-2002 22:50
What problems have you encountered using treads? M.I. Technical Discussion 8 15-01-2002 22:13
