Re: Maximum Depth of Cuts
indieFan |
Your maximun cutting depth is based primarily on the length of the cutting part of the bit. .200 sounds like a safe cutting depth for aluminum in general. What material is the 4 flute bit made out of? Does it have a coating on it? Since your using a relatively large diameter cutting bit and its 4 flute, you could go with more shallow cuts and just run through the metal faster since 4 flute can remove the metal more quickly in smaller chips.
Wait, I may have terminology screwed up. I thought DOC referred to either the depth that the end of a tool sank into a material OR the amount that a tool removed on its side. If not, is the latter referring the the Material Removal Rate (MRR)?
Regardless, I'm looking at how to figure out how much material can be removed using the side of the tool. indieFan |
| Maximum amount of stored energy? | pryoplasm | Technical Discussion | 1 | 19-01-2004 20:57 |
| the size of the shipping crate, the maximum dimensions?????????? | MASherry | General Forum | 5 | 13-01-2004 22:30 |
| To Maximum Oz and Two Train | Joe Matt | Thanks and/or Congrats | 1 | 09-03-2003 13:03 |
| maximum length of joystick cables | archiver | 2001 | 2 | 23-06-2002 23:54 |
