Go to Post I encourage the communication of constructive ideas on how to make FIRST a better program. - meaubry [more]
Go Back   Chief Delphi > Other > FIRST Lego League
Unread 26-04-2004, 23:22
Guyute Guyute is offline
AKA: John Whelan
no team (West Side BoilerInvasion)
Guyute has a spectacular aura aboutGuyute has a spectacular aura about
Send a message via AIM to Guyute Send a message via Yahoo to Guyute
RCX Programming
so heres my problem i'm trying to up load firmware and it keeps giving me this error "transfer data failed, unlock firmware failed...." i have already checked for dead batteries on the RCX and thats not the problem. are there any ideas out there for me? thanks.
2nd Place in CURIE
Top 20 in the Nation
Everyone should Try HOOKAH!
Unread 28-04-2004, 13:47
Re: RCX Programming
Three things,
Try changing to a different port for the tower and let software find it again. Enclose the RCX and tower in a box as there may be inteferring IR sources that interupt the data transfer. Remove the batteries for at least five minutes to let the memory drain all the way down, then try again.
I am of course assuming that the RCX hardware is compatable with the version of firmware you are loading. There are still some very early RCX bricks that are not able to load the more recent versions firmware.
Unread 28-04-2004, 14:38
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: RCX Programming
Make sure the IR tower is set on short range and the RCX is close to it (about 6 inches). If you are using something other than the default LEGO software to download it, try using the slow firmware download option. (if applicable.)
Unread 06-05-2004, 18:27
CmptrGk's Avatar
CmptrGk CmptrGk is offline
Programming Mentor
AKA: Dillon
FRC #0716 (Who'sCTEKS)
CmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud of
Re: RCX Programming
acually no you do not want the tower set to short range. you want it set to long range no mater what. it it is one of the old serial towers make sure that it has a good 9 volt battery
Unread 06-05-2004, 18:45
Programming User
Re: RCX Programming
Short range uses slightly less power, and if the RCX is too close, the long range can be too strong, causing interference. Hence my reason for saying short.
Unread 07-05-2004, 21:33
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: RCX Programming
Originally Posted by Al Skierkiewicz
... There are still some very early RCX bricks that are not able to load the more recent versions firmware.
That's an early brick! I have a RIS 1 brick, and it works fine. Are you talking about engineering samples?
Unread 10-05-2004, 07:33
Re: RCX Programming
We were told that some versions of the brick, not RIS, had different hardware/firmware and would have a problem running RIS2.0 or above. I have never personally come across any, but had it reported to me on one of the FLL boards. This is not the software problems people have had with RIS running on different OS like NT, etc. which is a different problem altogether.
Unread 10-05-2004, 10:29
Programming User
Re: RCX Programming
Are you saying that the software on the computer is incompatible with the firmware on the brick? If so, all you have to do is upgrade to the firmware that comes with whatever version of the software you are using. Or, switch to BrickOS...
Unread 10-05-2004, 11:56
Re: RCX Programming
Are you saying that the software on the computer is imcompatible with the firmware on the brick? If so, all you have to do is upgrade to the firmware that comes with whatever version of the software you are using. Or, switch to BrickOS...
No,
What I am saying is it was reported that firmware shipped with RIS 2.0 would not load/work on old bricks. I am just passing along an anecdotal report of firmware problems with very early bricks. I have not had any problems with current hardware or firmware.
Unread 11-05-2004, 11:47
AKA: Jamie Bliss
Re: RCX Programming
No,
I believe that is incorrect. My v1 Brick (that comes with RIS 1) works fine on the firmware shipped with RIS 2. When I say v1, I mean it has a power plug.
Unread 23-08-2004, 16:25
bubis bubis is offline
bubis is an unknown quantity at this point
Re: RCX Programming
Unfortunattely, all of a sudden, my RCX 2.0, stopped functioning.
It doesent even goes on and off.
The batteries are new.
I've tried to unlocking it by removing the batteries and holding the on/off button until I hear a beep as lego mentions, but nothing happens, no beep for me.
I would like to ask if there is a way to unlock the RCX.
I already opened it and it seems nothing's wrong inside..
Please help..
Autonomous Programming Competition Signup List SilverStar Programming 36 13-05-2004 15:09
Robot Programming Education phrontist Programming 11 03-05-2004 07:32
Using an FRC with the RCX? Astronouth7303 Programming 21 15-04-2004 14:14
Controlling a FIRST robot with a Lego RCX Controller? archiver 2001 5 24-06-2002 04:19
Pneumatics electrical wiring and programming archiver 2001 1 23-06-2002 23:10
