Re: Upgraded to vBulletin 3.0.1
I should've looked harder:
From vBulletin.com forums: Bright green dots are better than dark green dots and the more dots you have, the higher the reputation. Having any bright dots at all means you have a higher reputation than someone who only has dark green dots. Same thing with the red dots, just in reverse. The maximum number of dots you will see is 11 (in the current system). Reputation -99 to 0 0 to 99![]() 100 to 199![]() ![]() 200 to 299![]() ![]() ![]() 300 to 399![]() ![]() ![]() ![]() 400 to 499Once you hit 500, you will start gaining bright green dots on top of the 5 dark dots but it takes twice as much to gain a bright green dot. ![]() ![]() ![]() ![]() ![]() 500 to 699![]() ![]() ![]() ![]() ![]() ![]() 700 to 899![]() ![]() ![]() ![]() ![]() ![]() ![]() 900 to 1099![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() 1100 to 1299![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() 1300 to 1499![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() 1500 and up Negative values work pretty much the same way except it shows balanced (grey dot) from -99 to 0. Last edited by Brandon Martus : 12-05-2004 at 23:22. Reason: fixed images. |
I like the new 3d stuff its awsome
| Server upgraded. | Brandon Martus | Announcements | 4 | 05-01-2003 22:28 |
| successfully upgraded v2.2.4 | Brandon Martus | Announcements | 1 | 15-03-2002 00:07 |
