Go to Post I didn't know that Dean Kamen had 3 arms. - kevin.li.rit [more]
Unread 01-05-2004, 02:05
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Potentiometer with BS2
I was wondering how I would hook up a potentiometer to a BS2 and how I would program it to read the input. Microcontrollers and programming are really not my thing but I need to do this for a project I'm working on. Thanks.
Unread 01-05-2004, 09:41
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Re: Potentiometer with BS2
Are you talking about hooking it up to one of the old robot controllers (or to its operator interface) or in some other kind of project in which you are using a BS2?
Unread 01-05-2004, 10:19
Just a BS2, no IFI stuff.
Unread 01-05-2004, 10:33
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Check FotoPlasma's message below.
You'll need a A/D converter. The BS2 (or the project boards) doesn't include one. I'm not sure how you wire it to the BS2, though. Check Parallax's Website.
Last edited by Astronouth7303 : 01-05-2004 at 11:42. Reason: FotoPlasma has corrected me.
Unread 01-05-2004, 11:36
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
While it may be true that the BS2[add arbitrary suffix here] doesn't have an A/D converter, it does have the capability to measure a variable resistor. In the manual, check out the instruction POT (for the BS1) or the instruction RCTIME (for the BS2 and higher).
Hope this helps.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 01-05-2004, 15:46
Hope this helps.
Thanks a lot. That does help. I had seen that POT command before but seeing it was only for the BS1, I thought I wasout of luck. But RCTIME seems to be what I'm looking for. My end goal is to have the BS2 take a potentiometer reading in, and give a PULSOUT that is directly proportional to what the input is.
Unread 13-05-2004, 19:08
arpus maximus arpus maximus is offline
arpus maximus is on a distinguished road
Send a message via AIM to arpus maximus
If you are using an Innovation First RC, you just hook the potentiometer up as an analog sensor, and you're good to go, right?
ARP
Unread 13-05-2004, 19:21
Bharat Nain's Avatar
ARP
Yes, if you are using a Innovation FIRST RC, then you're fine...
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
initialization program and speed controllers rosebud Programming 15 05-10-2004 03:35
BS2 syntax (PBASIC) on the new controllers? Maybe! Jeremy_Mc Programming 0 25-10-2003 15:00
Potentiometer Problem Greg General Forum 1 15-02-2003 18:10
Bourns Inc Potentiometer archiver 2000 2 23-06-2002 23:06
Potentiometer Theory Ulibrium Technical Discussion 6 25-01-2002 21:16
