Go to Post I'm very excited for this year, because robots. - pyrtle [more]
Unread 02-04-2003, 19:22
Archon Archon is offline
#0967 (Mean Machine)
Archon is an unknown quantity at this point
Automatic Centrifugal 2-Speed
Could someone well experienced with tranmissions explain to me exactly how a 2-speed centrifugal tranny works? A picture of one such gearing is here.
It looks intriguing, but we can't figure out how the gears switch.
Behind every good computer... is a jumble of wires 'n stuff.
Unread 02-04-2003, 19:35
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I was kind of wondering the same thing. I found this which may help.
http://www.rccaraction.com/articles/2_speed2.asp
I know RCCA did an arcticle just about how they work and I have every issue from the last 4 years but I don't have time to look through them all. You might try sending an e-mail to them.
Unread 02-04-2003, 20:07
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
A google search also turned this up, although I don't know how useful/good it is: http://www.rctek.com/transmission/in...ny_design.html
Unread 02-04-2003, 21:09
Kevin A Kevin A is offline
In Hibernation
#0481 (DART)
Kevin A will become famous soon enough
Send a message via AIM to Kevin A
i know of a CVT transmision in cars that have 2 pulleys, and on is spring loaged to expand, the other is spring loaded to contract, with a centrifuagal expander on the contracting pulley. So it changes ratios as it spins faster.
Kevin Antaki
Team 481
AIM: xpalendocious
Unread 07-04-2003, 16:01
Archon,
Two speed transmissions are pretty common and have been used for some time. I became familiar with them on my washer a long time ago. Although the one you refer to appears to change gear ratio when the output shaft gets above a certain speed, my washer used the speed change on the input shaft to engage a centrifugal clutch to switch between agitate and spin. Centrifugal clutches had been used on garden tractors and tillers. When the engine RPM is below a certain point the engine shaft is disengaged from the output. Raise the engine RPM and internal weights force the clutch plates out and engage the engine shaft. (see the animation in Sanddrag's post.) In the first reference, I think the centrifugal part is the larger pulley on the left.
Unread 14-05-2004, 12:17
sburro's Avatar
sburro sburro is offline
AKA: Joe
FRC #0663 (crusaders)
sburro will become famous soon enoughsburro will become famous soon enough
Send a message via AIM to sburro
Re: Automatic Centrifugal 2-Speed
just want to reerect this post. Can anyone explain better or know where I can get my hands on one?
Unread 14-05-2004, 16:24
SpaceOsc's Avatar
SpaceOsc SpaceOsc is offline
16 Years of FIRST!
AKA: Oscar Vasquez
FRC #4501 (Humans)
SpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant future
Send a message via AIM to SpaceOsc Send a message via Yahoo to SpaceOsc
Talking Re: Automatic Centrifugal 2-Speed
Building it seems to be more a FIRST approach to it
2014-2017: Team 4501 Coach/Lead Mentor
2002-2011: Team 702, Mentor
2001-2002: Team 702 Captain
Unread 14-05-2004, 22:08
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Here is a part break down of the transmission in my rc monster truck. The 2 speed in my truck is interal and is not outside like most rc cars. This is mainly because they need to stay clean...
I am not sure how you could make one to work because they are very high speed. I believe the engine in my rc car spins at around 50,000 RPM!
2 speed
My Tmaxx truck
I am not sure if this will help you or not but this will give you a better understanding of how a 2 speed forward/reverse nitro transmission works.
There is also a 2 speed Emaxx truck that uses a servo to shift between gears I have never accually look at one but that might be something you want to look at! http://www.traxxas.com/products/elec...s-exploded.pdf
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 14-05-2004, 22:21
AKA: Bradley Rigdon
You can get one from tower hobbies $30 You may be able to find them cheaper if you look hard enough. You may also be able to buy one at a local hobby shop!
http://www2.towerhobbies.com/cgi-bin...?&I=LXDVA9&P=0
"Automatic Transmission" Madison Technical Discussion 70 24-11-2003 09:03
Power, speed, and torque... AGH Gui Cavalcanti Technical Discussion 5 10-11-2002 19:02
speed controllers archiver 2000 5 24-06-2002 00:19
Calibrating speed controllers and joysticks thedillybar Technical Discussion 4 11-02-2002 13:24
