Re: Making a Sensor Board
any other sensors? and i do mean ALL the sensors that i could find in my local kit of parts, we have sensor from back in 2001 till 2004 so i guess we have alot to work with. can anyone help? or a place i could get help thats not the spec sheets of first
I'm a programmer, so pardon me.
We used pots for finding the position of various parts. They're also used in joysticks and the like. Encoders are used to find if something has passed it. Most of us use the banners. What we did was put reflectors on a black axle adaptor and used 2 banners to see if it was high or low. see the white paper on quadrature encoders. Gyros can measure meassure angle of your robot (or something on it) if you use code. You need an accumulator to add the value at a regular interval. There are the touch sensors, but I hope those are obvious. (Digital) There are actually 2 pressure sensors. The one you MUST use is digital. The one you can use is analog. The former is turn compressor on/off. the latter is actual pressure. the voltage sensor is important if a motor has a high stall and/or if it can break your robot. Analog. if it crosses a certain threshold (High or low), kill the motor. The banners are also used for line following (on or off line). Anything else I missed? |
| Making your robot drive easier | ufa_mike | Control System | 32 | 28-04-2004 21:35 |
| Making .Hex files | dddriveman | Programming | 4 | 11-03-2004 13:47 |
| Wiring Diagram for making a Joystick | Nick Fury | Control System | 0 | 10-02-2004 23:10 |
| Rules on making spare parts fyi | DougHogg | General Forum | 0 | 02-04-2003 16:18 |
| Making a Dongle - Pin 1 help | DanL | Electrical | 6 | 05-03-2003 16:58 |
