Go to Post .....just don't hurt the programmer =) - mtaman02 [more]
Unread 15-05-2004, 11:19
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Making a Sensor Board
I'm a programmer, so pardon me.
We used pots for finding the position of various parts. They're also used in joysticks and the like.
Encoders are used to find if something has passed it. Most of us use the banners. What we did was put reflectors on a black axle adaptor and used 2 banners to see if it was high or low. see the white paper on quadrature encoders.
Gyros can measure meassure angle of your robot (or something on it) if you use code. You need an accumulator to add the value at a regular interval.
There are the touch sensors, but I hope those are obvious. (Digital)
There are actually 2 pressure sensors. The one you MUST use is digital. The one you can use is analog. The former is turn compressor on/off. the latter is actual pressure.
the voltage sensor is important if a motor has a high stall and/or if it can break your robot. Analog. if it crosses a certain threshold (High or low), kill the motor.
The banners are also used for line following (on or off line).
Anything else I missed?
Unread 15-05-2004, 11:43
Joshua May's Avatar
Joshua May Joshua May is offline
Go Bears!
FRC #1110 (Binary Bulldogs)
Joshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond repute
Send a message via AIM to Joshua May
Just the newer one, Infrared. The IR sensors search for an Infrared beacon and travel towards it. I don't know how these work, however, because my team did not use them this year.
The FIRST Wiki - openFIRST - Ultimate Robot Challenge - URC Wiki
I currently have 50 GMail invites, PM or email me for one.
UC Berkeley Class of 2009
2005 Las Vegas Regional Autodesk Visualization Award
2005 Las Vegas Regional #8 Seeded Alliance with 988 and 1505
2006 Southern California Regional #15 seed
Making your robot drive easier ufa_mike Control System 32 28-04-2004 21:35
Making .Hex files dddriveman Programming 4 11-03-2004 13:47
Wiring Diagram for making a Joystick Nick Fury Control System 0 10-02-2004 23:10
Rules on making spare parts fyi DougHogg General Forum 0 02-04-2003 16:18
Making a Dongle - Pin 1 help DanL Electrical 6 05-03-2003 16:58
