Go to Post *referring to Team Titanium's 2012 robot* If only it could play guitar hero at the same time. sigh. - rsisk [more]
Unread 17-05-2004, 14:01
arpus maximus arpus maximus is offline
arpus maximus is on a distinguished road
Send a message via AIM to arpus maximus
Radio Problems!! Please help
Okay, so we have a problem every day. (If you're not familiar, I'm making a full-size RC car). This time, it's with the radio system. We can control everything just fine when we use the tether, but as soon as we try to use the radios, nothing works.
We are using RS-422 Data Modems (of the IFI screamer variety) as it says to. On the RC, it blinks "No Data/Radio" and both the Rx and Tx radios have "standby" lit up.
What are some areas we might want to check on? Potential problems?
Thanks,
ARP
Unread 17-05-2004, 14:21
Marc P. Marc P. is offline
I fix stuff.
AKA: βetamarc
Marc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond repute
Send a message via AIM to Marc P.
Re: Radio Problems!! Please help
Check the team numbers on both the RC and OI. They must be the same in order to function via radio. They are set in binary via dip switches on the lower right hand corner of both pieces. Shouldn't matter what the number is, as long as they are the same on both sides.
Unread 17-05-2004, 14:34
We have already coordinated the team numbers. We are using the 2001 RC and OI by the way. Do we need to set the channels for the data modems or do they coordinate/program automatically? They are both on standby. Can you set one to receive and one to transmit or should they do it themselves?
Everything seems to be set up the way it dictates in the reference guide. Can anyone think of any reason(s) why they are not working?
Unread 17-05-2004, 14:43
REVving up for a new season
FRC #2848 (All-sparks)
try making sure you are using the right radio for each componet...the one with the opperator interface has a metal antenia, and the one for the robot controler has a hard rubber one.
Unread 17-05-2004, 14:45
yes, we have that set up correctly. The DB-9 work for the tether and for the program ports, is it possible that the same cables will not work for the RC-422 ports?
Unread 17-05-2004, 15:58
Greg McCoy's Avatar
Greg McCoy Greg McCoy is offline
boiler up!
FRC #3940 (CyberTooth)
Greg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond repute
Send a message via AIM to Greg McCoy
I think the same cables that work for the tether and program will work for the radio too (on 2000-2003 systems).
There are (at least) two different types of radio modems. One pair is used for communication between the Robot Controller and the Operator Interface. The other pair, which I believe is labeled "Ewave Screamer," is used for remote programming and debugging. If your radios say "Ewave Screamer" rather than "Innovation First" in big white letters, you probably have the wrong radio.
That's the only potential problem that I can think of at the moment from what you've said...good luck!
Unread 17-05-2004, 16:24
ewave used to make the radios for innovation first and the programing was just an extra feture but i am almost positive that they still worked as regular radios....
on a side note innovation first bought out ewave because they were not happy with the quality control of the product so it is possible that they radios are just bad...try asking the team you got them from for another set the ones from 02 and 03 should work the same
Unread 17-05-2004, 16:33
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
IFI bought the patents and information and designs of EWAVE but EWAVE the company is still around and they do some of the manufacturing still. If i remember correctly from what i remember is that the 2001 radios (i think) was the first year you needed the radios to be the same years models together. What i would suggest is to make sure that they are the 2001 radios and are the right set. The radio style changed from 300 something to 422's in 2002 or 2003 so you may not have the correct radio set in the firmware. i would suggest to contact ifi to get the specs on the legacy system and modems to make sure all your hardware is compatable and correct.
-Michael Dessingue
Unread 17-05-2004, 16:58
Andy A. Andy A. is offline
Getting old
FRC #0095
Arpus-
Could you discribe the situation a little more in depth? Specificly, were physicly are the radios in relation to eachother? Do they have a clear line of sight to eachother? Is one close to the car frame? Are they both out on a test bed?
Also, what are you using for the OI's power supply? It should output 9volts 1500mA. Using underrated supplys will get all the lights to blink and look healthy, but the radios may not have enough power to communcate. In anycase, range will be severly affected.
If you have not done so already, place both radios a few feet apart with a clear line of sight. If they do not manage to establish a link within 10 to 15 seconds, they are probably damaged (most 'bots manage to link up under 3 seconds).
Check that the power supply is adequate, both radios start with a clear line of sight and that both are placed away from anything that could be 'noisy'. I susepect that a car frame could present a serious problem with communication. I would strongy suggest that you place the reciver high up and away from the rest of the car if feasible.
-Andy A.
Unread 17-05-2004, 17:07
Kyle Fenton Kyle Fenton is offline
GET IT ON!!
FRC #0121 (Rhode Warrior)
Kyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud of
Send a message via AIM to Kyle Fenton
Thanks,
ARP
Do you have a dongle on your OI. I know there is a pin, when activated deactivates your radio.
Rhode Warriors
NAVSEA/Raytheon/URI/Middletown, Portsmouth, Tiverton, Mt. Hope HS
Quality Robots Since 1996
Unread 17-05-2004, 20:23
We were using a 9V AC adaptor to power the OI, which would seem to be enough (we don't have the original AC adaptor included with the OI, but I believe it was a 9V adaptor). Is it possible that we should use something with MORE voltage, such as a 12 or 15 volt adaptor?
However, the OI says "Low Battery" while using the bootleg 9V adaptor that we found lying around.
Also, we tried setting the receiver and the transmitter up within a few feet of one another, and yet they still didn't work.
What is a dongle? That sounds funny. In any case, I doubt we have one.
ARP
Unread 17-05-2004, 20:30
ARP
Just a question a little OT. Your profile says your not on a team now, were you ever on a team and if not what team is this control system borrowed from?
-Michael Dessingue
Unread 17-05-2004, 21:32
Greg McCoy's Avatar
boiler up!
You need to use the provided AC adapter. I believe the OI requires 1.5 amps at 9 or 12 VDC (not 100% sure which), most "wall-wart" transformers can't provide this. This would explain your radios not working properly. I've seen OIs only partially light up and do all sorts of wierd things when they aren't getting enough juice.
They are referring to something that plugs into the competition port on top, which would be used to change channels, disable the robot at a competition, etc.
Unread 17-05-2004, 22:04
Getting old
FRC #0095
ARP
Arp
I think your problem may be two fold.
First- the adapter must be 9 volts. Anything higher and you risk damage to the OI. It also should put out 1500mA (1.5 amps). You can check this fairly easily. On the wart it's self, it should have a label. On this label, look for what ever comes after 'Output:'. It should read something like '9VDC 1500mA. If it is less then this rating, then the OI will work, but the radio will probably not have enough juice to really transmit at the level needed.
Secondly. You mentioned that the low battery light is on. If this light is one when you are teatherd, then your RC is probably not getting enough power either. That light comes on when the RC's voltmeter drops to a certain level. This value can be changed int he program, but I think it defaults to 10 volts. Usally this doesn't cause radio problems, but I have noticed it can crop up when using a very old battery or if there is a bad connection between the RC and the battery. How is the RC being powered? Did you end up powering through the cars 12volt system? Did you ever check the quality of that power? It may not be adequate. If this is the case, then your RC radio may not be fully powered, which could result in the same symptom. Check the voltage at the RC's power terminals with a voltmeter. It should read right around 12v, give or take 2.
-Andy A.
Unread 17-05-2004, 22:08
Venkatesh Venkatesh is offline
FRC #0030
Venkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to behold
Thumbs up Re: Radio Problems!! Please help
Alright.
The 2001 Innovation First-provided Radios (in the kit) were RS422 EWave Screamers. They are labelled similarly to the 2004 radios, except most of the blue text on the 2004 radios were red on the 2001 sets. The remote programming radio was the called the Stamper, if I recall correctly. Very few teams I know of purchased them, as they were expensive.
I would test the radios on another set of Operator Interfaces and Robot Controllers. Also, the antenna wire inside the OI radio has come loose on two of the 2001 radios I have looked at. Take a look there as well.
Good luck.
-- vs, me@acm.jhu.edu
Mentor, Team 1719, 2007
Team 30, 2002-2005
Radio Problems KWalsh Programming 3 24-02-2004 17:25
need 2003 radio/help with old radio MaxM Technical Discussion 2 04-01-2004 15:31
EduRobotics problems Ian Mackenzie Robotics Education and Curriculum 22 14-12-2002 11:33
Joystick problems archiver 2001 3 24-06-2002 02:40
Radio problems -- not archiver 2000 1 23-06-2002 22:23
