Go to Post Winning just makes your ego smile. - MooreteP [more]
Unread 20-05-2004, 20:22
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
White Paper Discuss: Code and Walkthrough for Global Positioning System using IR Sensors
Thread created automatically to discuss a document in the White Papers.
Code and Walkthrough for Global Positioning System using IR Sensors by Grommit
Unread 20-05-2004, 20:54
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: White Paper Discuss: Code and Walkthrough for Global Positioning System using IR Sensors
Just a couple of questions and comments:
1. Satellite GPS does not use the angle the signal is traveling at, it uses the distance from the satellite to the device
2. I believe that you do not need to use your "firstrun" variable and loop to initialize the static variables, i believe you can just define statics when you declare them
static int myVar = 5;
and the definition will only happen the first time the function is called, so the variable won't be changed by the definition/declaration statement in successive function calls.
3. Have you run this code on a FRC? It seems like it, along with the neccesary parts of the default code, could start to cause "default_routine" to start missing cycles as some people have mentioned has happened, if this code is running in every cycle in "default_rountine".
I like the use of a 4th sensor for error correction, pretty cool. If you have used this system, how did it work, if not, post about it when you do.
Team 1257
Unread 20-05-2004, 21:22
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Very cool. My only concern is speed with floats. As maxlobovsky said, it can cause it to miss cycles. My thought is to do this either in parts (state machine), or do getdata and putdata in the middle of it.
