Go to Post First check for any bind in the transmissions, especially chain. Next, check to see if the motors are O.K. Use code as a last resort. - Paul Copioli [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 22-05-2004, 18:19
Guest
Posts: n/a
Re: PHP Question
This should work.
You can't "echo" an array. nl2br converts all new lines into HTML <BR> tags.
Correct code:
PHP Code:
$poem = $_POST['poem'];
<?if($poem == ""){
echo(
"no poem");
}else{
$show nl2br($poem);
echo(
"$show");
Question of the Week [05-02-04]: The Very Merry Month of May EddieMcD Rumor Mill 10 05-05-2004 14:02
A question about control system options computhief263 Control System 7 04-02-2004 14:46
php vs. perl Jack Website Design/Showcase 20 29-12-2002 17:01
What's better, PERL/cgi or PHP/my_sql? mikefrei Programming 10 27-05-2002 22:50
