Go to Post I know that this might be a foreign concept but teams help each other out all the time. - Al Skierkiewicz [more]
Unread 26-03-2002, 23:52
HotWheels2002's Avatar
HotWheels2002 HotWheels2002 is offline
#0007 (Firestorm 4)
HotWheels2002 is an unknown quantity at this point
Send a message via AIM to HotWheels2002
Exclamation Illegal use of springs?
Does anyone know if a team is allowed to keep a breaker from tripping using a spring? We had an inspector say "no way" after having used this idea for the past four years or so.
(PS - I am not part of the electronics sub-group on the team, so the closer to common knowledge vocabulary that the responses are, the better.)
FIRST 2002 Johnson and Johnson Mid-Atlantic Regional Winners.
2002 General Motors Industrial Design Award Winner.
http://www.phsrobotics.com
AIM me: imagine02lennon
Unread 27-03-2002, 00:07
You should not be able to prevent a breaker from electrical tripping by holding the handle. This is a saftey feature required on breakers to prevent homeowners from burning their house down by holding a tripping breaker in the "ON" position. It may help with impact tripping but as I remember in our tests it did nothing to prevent trips of any kind. Read the discussion of breaker construction in the robot appendix.
Good Luck
Unread 27-03-2002, 00:17
#0007 (Firestorm 4)
I figured...
I figured that was the case....I wonder why we were forced to remove that spring before competition at Rugers? After some small electrical problems at VCU, we were trying to take every precaution to prevent these problems. Thanks Al.
Unread 28-03-2002, 22:59
Anytime, glad to help.
Unread 10-04-2002, 11:39
ECarlson's Avatar
ECarlson ECarlson is offline
AKA: Eric Carlson
#0116 (Epsilon Delta)
ECarlson has a spectacular aura aboutECarlson has a spectacular aura about
Re: Illegal use of springs?
I think at the 2001 kickoff, one of the presenters mentioned that you might want to install a device to keep the breaker from tripping due to collision forces, so a spring should be acceptable for that.
We never had a problem of the breaker tripping that way, but some teams do put in preventive devices.
- Eric
www.InvisibleRobot.com Updated: August 24, 2008
Over 28,000 FRC & FTC Photos , Team 116 OI adapter board info
Unread 10-04-2002, 12:15
Teedoff101 Teedoff101 is offline
#0992 (Oakwood Robotics)
Teedoff101 is an unknown quantity at this point
We used a spring like device to keep our breaker from tripping -- but we used it as a shock absorber between the breaker and the frame, not holding the switch.
Unread 10-04-2002, 12:33
ECarlson's Avatar
AKA: Eric Carlson
Clever idea. Did the springiness make the switch harder to turn on and off?
- Eric
Unread 10-04-2002, 12:41
Greg McCoy's Avatar
Greg McCoy Greg McCoy is offline
boiler up!
FRC #3940 (CyberTooth)
Greg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond repute
Send a message via AIM to Greg McCoy
It seems like that sort of setup would be perfectly legal, as long as you used allowable parts and did not modify the circuit breaker.
Unread 12-04-2002, 13:46
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
They should have no reason for stopping the switch from tripping. The breaker trips internally and has nothing to do with the switch...
The best moments of our lives fall in two categories: those that did happen and those that did not.
Unread 12-04-2002, 21:43
Gui Cavalcanti's Avatar
Gui Cavalcanti Gui Cavalcanti is offline
Robogeek
Gui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to all
Send a message via AIM to Gui Cavalcanti
Velcro?
Our breaker is mounted to lexan on the top of our bot so that just the switch pokes out of the top. We use velcro straps (with stick velcro on the lexan itself) to hold the breaker in the on position.
We don't really do this for electrical reasons... I can't see us pulling down more than 60 to 70 amps continuously anyway. We do it because the breaker is on top of the robot and that's where balls tend to come down on... I know, we should have rethought the system, but it was far too late to move the breaker to a convenient location.
Gui Cavalcanti
All-Purpose College Mentor with a Mechanical Specialty
Franklin W. Olin College of Engineering, Class of 2008
Unread 13-04-2002, 00:54
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
I'll answer that. As a quick fix before inspection, we unscrewed our breaker from the frame, laid a piece of latex tubing down flat where our breaker was, and screwed the breaker back down on top of the tubing. This whole operation took less than five minutes, and we never had the breaker trip after that. It didn't make the breaker that hard to switch, as the latex could only be compressed half a centemeter at most.
Zan Hecht
Unread 13-04-2002, 01:00
ECarlson's Avatar
AKA: Eric Carlson
Another good, and easy idea.
- Eric
Unread 16-04-2002, 23:14
#0007 (Firestorm 4)
Actually, we had the other end of that spring around a bolt that we mounted off of our battery carrier. The spring never had to come off of the switch, rather it came off of the bolt when we turned it off (the distance between the bolt and the breaker switch was just a bit more than the length of the spring to make it tight). The whole on or off process took maybe 8 seconds (we'd simply take the end of the spring off of the bolt).
Stupid Laws linkin48603 Chit-Chat 45 25-05-2003 18:31
springs hi_im_sean Technical Discussion 4 23-01-2003 19:05
News Flash: Sandpaper for traction is illegal D.J. Fluck General Forum 8 21-01-2003 11:45
Is it illegal to lift another robot off the ground? Tton Rules/Strategy 19 14-01-2003 21:28
springs CharlieWilken Technical Discussion 3 30-01-2002 19:39
