Go to Post I am just very happy that I have never been responsible for the spelling of Karthik's last name on a name tag. Seriously. - JaneYoung [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 23-05-2004, 16:41
Raven_Writer's Avatar
Raven_Writer Raven_Writer is offline
2004 Detroit & Pittsburgh Winners
AKA: Eric Hansen
FRC #0005 (RoboCards)
Raven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really nice
Send a message via ICQ to Raven_Writer Send a message via AIM to Raven_Writer Send a message via MSN to Raven_Writer Send a message via Yahoo to Raven_Writer
MySQL/PHP Query question
I've decided to create a comment script for a beginning project. Right now, I'm working on the registering part of the script. My problem is checking to see if the username already exists within the database. Here's the code I'm using right now:
PHP Code:
$user
$_POST['username'];
$pass $_POST['password'];
$check $_POST['passcheck'];
$conn mysql_connect(/* connect to mysql */);
if(!
$conn){
 echo(
"Unable to connect to MySQL: "mysql_error());
 exit;
$db mysql_select_db(/* try to connect to database */);
if(!
$db){
 echo(
"Unable to select database: "mysql_error());
 exit;
/* ::: LOOK BELOW ::: */
$result mysql_query("SELECT * FROM information WHERE user = '"$user ."'");
if(
$result != ""){
 echo(
"Username already exists in database.  Please choose a different username to continue.");
 exit;
/* ^^^^  LOOK ABOVE ^^^^ */
I can connect to MySQL and the database just fine.
AIM: wisprmylastbreth
EMail: nightskywriter@gmail.com
Y!: synsoflife
"ai yoru ga" -- "Love the nights"
Unread 23-05-2004, 20:57
Guest
Posts: n/a
Re: MySQL/PHP Query question
Two suggestions:
1. Instead of using ($result !="") use:
PHP Code:
(mysql_num_rows($result)>0
2. (Only try 2 if 1 does not work) Put double quotes instead of single quotes around the user in the query.
Unread 24-05-2004, 09:52
mtrawls's Avatar
mtrawls mtrawls is offline
I am JVN! (John von Neumann)
#0122 (NASA Knights)
mtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to behold
Send a message via AIM to mtrawls
Now, I'm no PHP-guru, actually I've never used it before ... but from my experience using perl/cgi I tend to be a bit paranoid. But safely so. The cardinal rule is never trust the user; taint check, taint check, taint check! Not being familiar with PHP, like I said, I don't know if it's possible to do any sort of attack against a script of this nature, but I suspect there is. (Granted the short snippet you show may not suceptible, it's still a good idea to check your input.) E.g., if someone is entering a user-name make sure it only contains allowed characters and is correctly formatted. In perl, anyway, you'd be suprised how easy it is to pass 'rm -r .*' as an argument to something and watch for disastrous effects!
Just a friendly security reminder ... it never hurts to start good habbits early (since you said you were learning PHP). Maybe someone more experienced can comment about specific security woes that you'll have to look out for. But remember that paranoia is good.
Unread 24-05-2004, 11:31
Robert Hafner's Avatar
Robert Hafner Robert Hafner is offline
FIRST Alumni
Robert Hafner is on a distinguished road
Send a message via AIM to Robert Hafner Send a message via MSN to Robert Hafner Send a message via Yahoo to Robert Hafner
Change
PHP Code:
if($result != ""){
 echo(
 exit;
to
PHP Code:
if($result){
  echo(
 exit;
If you need any more MySQL or PHP help, email me, go to my team's website (which was built by me using PHP/MySQL), or check out this project I'm heading, supermod.org.
Unread 24-05-2004, 15:18
AKA: Eric Hansen
Thank you all for your help. But while waiting for a reply, I was messing around with it, trying to see if I could fix it myself. I still have the same trouble, and here's my code now:
PHP Code:
$result mysql_query("SELECT `user` FROM information WHERE `user` = '"$user ."'");
if(!
$result){
$result mysql_query("INSERT INTO `information` (`user`, `pass`) VALUES('"$user ."', '"$pass ."')");
 if(!
$result){
  echo(
"Unable to add user: "$user ." to database.  Please try again.");
  exit;
 } else{
  echo(
"Thank you for registering <b>"$user ."</b>!  Please enjoy your stay here.");
} else{
 echo(
"The username <b>"$user ."</b> was already found in the database.  Please go back and fix this problem.");
Anyone have any idea?
Y!: synsoflife
Unread 24-05-2004, 18:04
Guest
Posts: n/a
Did you try the mysql_num_rows suggestion above?
Unread 24-05-2004, 18:09
AKA: Eric Hansen
I just tried it, and it works perfectly. Thank you very much (man I wish I would've done that before...heh).
Y!: synsoflife
Question of the Week [05-02-04]: The Very Merry Month of May EddieMcD Rumor Mill 10 05-05-2004 14:02
MIM's question of the day on programming. Gene F Programming 3 24-02-2004 16:32
A question about control system options computhief263 Control System 7 04-02-2004 14:46
MySQL query question Jack Website Design/Showcase 9 02-02-2003 00:11
