Apache Root
I just installed apache but I cant find the root dir. so I can replace the default page... HELP!
Re: Apache Root
What system are you on?
Any more info? |
Re: Apache Root
Look in your apache confuguration file (httpd.conf) for the DocumentRoot setting.
Re: Apache Root
its just the "out of the box config" running on XP
Re: Apache Root
Try Joe's suggestion. If you still can't find it, I would suggest right clicking on of the pictures of the default page, get the picture filename and try searching for it.
Ok.
If you installed Apache on Windows, by default the root document dir is C:\Program Files\Apache Group\Apache\htdocs or C:\Program Files\Apache Group\Apache2\htdocs, based on what version you are running. I have been using Apache 1.3.x under Windows for a long time for my site (endeavour.zapto.org) and I have found it both slow and incredibly stable. I have found Apache 2.0.49 (the only 2.0.x I have used under Windows) to be very fast and rather unstable. If you want me to send you my config files and other details, PM me. Good luck Apache-ing. |
#7
Re: Apache Root
awsome \htdocs works!
Re: Apache Root
look for a folder called htdocs, possibly in c:\apache\ .. assuming thats where you installed it.
#9
Re: Apache Root
I was about to help you 'cause I figured it was on your Mac. But XP...erp. Good luck *crosses self* --Petey |
| Square Root Function not working | bludstayne | Programming | 7 | 15-02-2004 12:09 |
| Square Root | bludstayne | Programming | 3 | 14-02-2004 14:48 |
| Aspartame | shyra1353 | Chit-Chat | 8 | 20-01-2004 22:41 |
| PHP or ASP.Net? | Greg | Website Design/Showcase | 37 | 26-07-2003 02:29 |
| Installing Apache / PHP | Daniel Brim | FIRST Scouting Network | 2 | 16-06-2003 17:06 |
