Go to Post Note to self: Before turning 30, remember to remove the birthdate year from Delphi. - Jessica Boucher [more]
Unread 25-05-2004, 11:07
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Globe gear box
Finding the speed with a wheel is quite simple. You take the rpm of theof the wheel and multiply it by the wheel circumference(pi*diameter) to find linear speed. If your wheel is measured in inches and you are using rpm for roational speed, your linear speed number you got from the above calculation willl be in inches per minute. So, divide by 12 to get feet per minute and then divide by 60 to get feet per second.
Reverse Gear FizMan Technical Discussion 12 26-04-2004 01:29
Drill motor in a Dual Motor gear box MBosompra Technical Discussion 3 16-01-2004 21:37
Please help! Grease in the drill motor gear box? archiver 2000 2 23-06-2002 23:07
Grease inside the Drill Motor gear box? archiver 2000 2 23-06-2002 23:07
power of globe motor with gear box? Ken Leung Motors 5 21-11-2001 13:43
