Go to Post FIRST isn't a competition. It's a learning experience. Share the knowledge, and you'll learn more because there's bound to be someone who sees something about your project that even your own team didn't realize it can do. - CalTran [more]
View Poll Results: Shutdown or not?
Yes. 2 9.52%
No. 16 76.19%
I don't know what this is! 3 14.29%
Voters: 21. You may not vote on this poll
Unread 25-05-2004, 00:00
Guest
Posts: n/a
Shut down Code Repository?
Since there has been no code posting to the repository for some time. I will be shutting it down if nobody wants to use it. If shutdown, the content will still be there, but it will be archived and opened again only when it needs to be used.
Anybody wants to use it?
Whatever your answer to the poll, provide an explanation so I can determine whether to keep it or not.
Unread 25-05-2004, 00:02
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: Code Respository to shut down
don't! i think it has some excellent potential. I plan on contributing a very large chunk of stuff (or maybe many small chunks, whatever) as soon as i finish it and actually test it sometime this summer. You have got to give it time to get off its feet.
and look, 2/2 people agree with me!
Team 1257
Unread 25-05-2004, 00:09
Joshua May's Avatar
Joshua May Joshua May is offline
Go Bears!
FRC #1110 (Binary Bulldogs)
Joshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond repute
Send a message via AIM to Joshua May
I think you should keep it. I'm curently working on some projects that I will post in the repository, I just need to finish and test it.
The FIRST Wiki - openFIRST - Ultimate Robot Challenge - URC Wiki
I currently have 50 GMail invites, PM or email me for one.
UC Berkeley Class of 2009
2005 Las Vegas Regional Autodesk Visualization Award
2005 Las Vegas Regional #8 Seeded Alliance with 988 and 1505
2006 Southern California Regional #15 seed
Unread 25-05-2004, 00:16
Guest
Posts: n/a
For those of you who don't know what the respository is:
http://www.chiefdelphi.com/forums/sh...ght=repository
The repository site is: http://nrg.chaosnet.org/repository
Unread 25-05-2004, 13:41
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
No! You'll Kill Yourself!
Really. Don't. I'll post the team code this weekend.
Unread 25-05-2004, 14:07
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
I'll post ours too. Isn't anything terribly special, but it's a good example of a state machine.
Unread 25-05-2004, 14:41
Fold em oval!
Re: Shut down Code Repository?
Speaking of the repository, here is a feature im sure everyone would appreciate: A way to dl the database and easily access it without internet access. Something like a dynamically generated html (more like a set of htmls...), pdf, doc or excel that contains the all the info the web based db has; user who posted, dates, comments, revisions, etc...
Team 1257
Unread 25-05-2004, 15:24
Guest
Posts: n/a
I think I can do that.
I'm thinking of going with a PDF document and XML document "export" feature. I've started working on the PDF one. The XML should be easy.
Unread 25-05-2004, 15:46
Fold em oval!
And one more thing i forgot to mention, its important that the exported file has lots of indexing. There is so much content that is so hard to access.... (i mean in life, in general, not your repository..)
Team 1257
Unread 25-05-2004, 17:39
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
Whether intentional or not, you just spurred quite a few submissions. Social Engineering, or naivete?
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 25-05-2004, 20:07
Joshua May's Avatar
Go Bears!
And I have one suggestion if you keep the repository up (please do). YOu should have a section devoted to the entire robot programs, just with zip files of the projects that teams use. This way we can see more of the full aspect of programs.
Unread 25-05-2004, 20:14
Fold em oval!
good idea, i was wondering how to handle all the code i want to contribute. Then i code take the important/innovative/whatever parts and put them in as snippets in Robot Alogirthms or wherever appropriate.
Team 1257
Unread 25-05-2004, 20:32
Joshua May's Avatar
Go Bears!
The main reason I made the suggestion, beyond just seeing how it all fits together, is that in some cases programs will require functions in other places, or fast and slow loop code, or included files, etc.
What is your most prefered programming language? Hailfire Programming 156 19-01-2005 21:42
Interrupt timer, executing code asap? SeanCassidy Programming 10 07-03-2004 01:47
Does your team use the Default code. Jeff McCune General Forum 2 09-01-2003 14:46
