Go to Post The weight sounds about right, too. If you need more than 65 pounds for your manipulator, then the drivetrain isn't the part you should be redesigning... - s_forbes [more]
Unread 26-05-2004, 01:22
PaPPy PaPPy is offline
AKA: Brian Papile
None #0069 (HYPER)
PaPPy is on a distinguished road
Send a message via AIM to PaPPy
VB6 Question
I'm looking for a way to save a text box to a MSWord .doc using VB6. I've tried some things but they aren't working. If I can get it to work I also need to set margins and font size and font name.
I'd Appricate any help I can get with this.
~-PaPPy-~
Unread 26-05-2004, 17:33
Guest
Posts: n/a
Re: VB6 Question
There are two methods to do this:
1. Save the file in RichText format (.rtf). This can be read using Word. Put a RichTextBox on a form, insert the text into the RichTextBox control, and use the SaveFile method of the RichTextBox.
2. If you want to save it in .doc format directly, go here:
http://support.microsoft.com/default...12&Product=vbb
It explains exactly how to do it in the More Information section.
Unread 26-05-2004, 21:27
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: VB6 Question
Wow. I would have used VBA or something. Nice!
Unread 26-05-2004, 21:30
Guest
Posts: n/a
Re: VB6 Question
VBA would only work if PaPPy was writing a VBA program in the first place. If he wants to save a .doc file from VB, he'll have to do it externally.
Unread 26-05-2004, 21:52
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
Re: VB6 Question
First, add a reference to the "Microsoft Word 10.0 Object Library" from the Project->References menu.
This subgroutine will create a new word document and write a block of text to it:
Sub WriteWordDoc(content As String, _
                 filename As String, _
                 Optional font As String = "Verdana", _
                 Optional fontsize As Integer = 10)
    Dim app As Word.Application
    Dim doc As Word.Document
    'get an instance of the MS Word application
    Set app = CreateObject("Word.Application")
    'create a new document
    Set doc = app.Documents.Add
    'initialize the document and write the content
    With doc.content
        .font.Name = font
        .font.Size = fontsize
        .Text = content
    End With
    'save the document and close Word
    doc.SaveAs filename
    doc.Close
    app.Quit
    Set doc = Nothing
    Set app = Nothing
End Sub
The app.Quit line is important, otherwise it will keep Word open in the background. If you add the line "app.Visible = true" and remove "app.Quit" then you will see Word open with your new document.
Unread 27-05-2004, 07:32
AKA: Jamie Bliss
Re: VB6 Question
    With doc.content
        .font.Name = font
        .Text = content
    End With
    doc.SaveAs filename
    doc.Close
    app.Quit
    Set doc = Nothing
    Set app = Nothing
End Sub
Will a similar setup work with other versions of office? (and won't the 'doc.Close' make 'app.Visible = true' a little useless? Slight bug.)
Unread 27-05-2004, 11:54
None #0116
Re: VB6 Question
I would suggest you try using C# or VB.NET if you're just getting started with VB. The VS 6.0 tools won't be supported forever and you can do everything (and a lot more) with the .NET SDK.
Here is a sample class that has a method to save the information to a Word document. It only has two properties, Name and Bio. The Name will be written in 12pt Bold and the Bio in 10pt normal font. There is an overload that defaults to hiding and closing Word.
public class Person
	private string name;
	private string bio;
	public Person()
		name = string.Empty;
		bio = string.Empty;
	public Person(string n, string b)
		name = n;
		bio = b;
	public string Name
		get { return this.name; }
		set { this.name = value; }
	public string Bio
		get { return this.bio; }
		set { this.bio = value; }
	//overload of the ToWord method that does not display Word
	public void ToWord(string filename)
		this.ToWord(filename, false);
	//ToWord method writes the bio information to a new Word document.
	//the Show argument specifies whether we keep Word open.
	public void ToWord(string filename, bool show)
		//pointer to Word application
		Word.Application app = new Word.Application();
		//create a new document
		object opt = Missing.Value;
		Word.Document doc = app.Documents.Add(ref opt, ref opt, ref opt, ref opt);
		Word.Paragraph p;
		//add a new paragraph and write the person's name
		doc.Content.InsertParagraphAfter();
		p = doc.Content.Paragraphs.Item(1);
		p.Range.Font.Name = "Verdana";
		p.Range.Font.Size = 12;
		p.Range.Font.Bold = 1;
		p.Range.Text = this.name;
		//add a new paragraph and write out the bio
		p = doc.Content.Paragraphs.Item(2);
		p.Range.Font.Size = 10;
		p.Range.Font.Bold = 0;
		p.Range.Text = this.bio;
		//save the document
		object file = filename;
		doc.SaveAs(ref file, ref opt, ref opt, ref opt, ref opt,
				ref opt, ref opt, ref opt, ref opt, ref opt, ref opt,
					ref opt, ref opt, ref opt, ref opt, ref opt);
		if (!show)
			doc.Close(ref opt, ref opt, ref opt);
			app.Quit(ref opt, ref opt, ref opt);
		else
			app.Visible = true;
Question of the Week [05-02-04]: The Very Merry Month of May EddieMcD Rumor Mill 10 05-05-2004 14:02
MIM's question of the day on programming. Gene F Programming 3 24-02-2004 16:32
A question about control system options computhief263 Control System 7 04-02-2004 14:46
Chief Delphi Site Question Mike Bonham General Forum 1 16-02-2002 22:18
