Go to Post I think applying Gracious Professionalism to strictly legal game play trivializes what is a much more important and fundamental FIRST concept. - jimfortytwo [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 28-05-2004, 16:55
Venkatesh Venkatesh is offline
FRC #0030
Venkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to behold
MySQL on Windows
Hello everybody,
I have been running Apache 1.3.31 on Windows for quite some time now, and I am happy with the results. Apache on Windows isnt as fast as under Unix(ish) OSes, but it is very stable.
I want to create a database system for my site now. The machine is old (Pentium 166MHz, 64MB RAM). Should I put MySQL on that machine itself, or set up a second system as a database server?
If I were to go with the second machine, the system would be a Pentium 233MHz, 160MB RAM. Should I load Linux on this second machine or Windows? Is MySQL really useable under Windows?
Thanks.
-- vs, me@acm.jhu.edu
Mentor, Team 1719, 2007
Team 30, 2002-2005
Unread 28-05-2004, 18:39
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: MySQL on Windows
My dad says you should be ok, but a little short on RAM.
Unread 28-05-2004, 18:56
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Well if its gonna be a dedicated MySQL box, use linux. I can't say from personal experience, but all the statistics and tests show that this is one of the applications where one really should, and people really do, use linux.
Team 1257
Unread 29-05-2004, 07:01
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
On the dedicated or the one with Apache?
Unread 29-05-2004, 08:48
Raven_Writer's Avatar
Raven_Writer Raven_Writer is offline
2004 Detroit & Pittsburgh Winners
AKA: Eric Hansen
FRC #0005 (RoboCards)
Raven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really nice
Send a message via ICQ to Raven_Writer Send a message via AIM to Raven_Writer Send a message via MSN to Raven_Writer Send a message via Yahoo to Raven_Writer
I've ran MySQL 3.x on a pretty old system (forgot the specs...it's basically trashed now), but it ran pretty good. I didn't run into any problems, and it had Win98 installed on it.
AIM: wisprmylastbreth
EMail: nightskywriter@gmail.com
Y!: synsoflife
"ai yoru ga" -- "Love the nights"
Unread 29-05-2004, 10:54
AKA: Jamie Bliss
yes. I mean, I read it to my mom who relayed it to my dad and that's what he said.
Unread 27-06-2004, 19:12
Timothy D. Ginn's Avatar
Timothy D. Ginn Timothy D. Ginn is offline
I check here maybe once a year.
Timothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to all
Send a message via ICQ to Timothy D. Ginn Send a message via AIM to Timothy D. Ginn Send a message via MSN to Timothy D. Ginn Send a message via Yahoo to Timothy D. Ginn
Thanks.
Depending on whether it's just light databasing or not, you may also want to look into SQLite:
http://www.sqlite.org/
See also: http://www.php.net/sqlite
Personally, if I were you and I were running MySQL, I'd run it on Linux... it just seems easier that way. I've successfully run MySQL on machines of system stats lower than the one you're looking at for databasing, so you should be fine. If you're installing Linux, remove what you don't need (but that's always good advice, anyway).
That said, MySQL is usable on Windows, and I've done so before. I haven't really gone beyond testing openFIRST with it (which was the reason I set up MySQL, for compatibility testing of openFIRST with Windows and various version combinations of webserver/PHP/database), though I know of other people who have.
[edit]
P.S. Maybe I should start following you around and answering your questions, I seem to be doing a fair bit of that lately, anyway.
Alumni of FRC Team 1006
Former mentor of Full Lego Alchemist (FLL 5621) - Sempar School / Computing Students' Association of Queen's University
Makefile for programming under Windows with cygwin wun Programming 17 20-09-2004 00:44
Malware, Adware and Spyware JohnBoucher Technical Discussion 41 16-05-2004 22:51
Linux And Windows XP Raven_Writer Chit-Chat 4 06-08-2003 18:53
Message Boards w/o MySQL iBob Website Design/Showcase 7 13-07-2003 02:00
Windows ME robot180 Chit-Chat 11 07-07-2003 00:21
