Go to Post I had a life before FIRST - I just can't remember what it was. - Tom Ore [more]
Unread 29-05-2004, 13:24
mtrawls's Avatar
mtrawls mtrawls is offline
I am JVN! (John von Neumann)
#0122 (NASA Knights)
mtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to behold
Send a message via AIM to mtrawls
Re: Template Project
Originally Posted by Astronouth7303
I'm making a Template Project. What do you want in it?
You might add some debug/test routines. E.g.,
Set_Debug_Level (HIGH); // or maybe Set_Debug_Level (5), etc.
debug (msg, threshold); // i.e., if debug level < threshold, print msg
eq (some_var, some_val, severity); // i.e., if some_var!=some_val do action based on severity
// etc., more tests/debug features
Just a thought ... it's nice sometimes to write code based on certain tests, and since you don't always have the robot with you while coding, it can be helpful to print out errors where something unexpected occurrs, but then have it go silent when you are doing the competition ... but still have it ready to go if you change something and need to make sure it all works. Wow, I'm going to stop rambling now.
Unread 29-05-2004, 13:31
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
No, no. that's the point. And it's better than mine, I think.
Math project edomus General Forum 4 01-04-2004 13:12
Preseason project AdamT General Forum 4 09-09-2002 00:52
project box archiver 2000 2 23-06-2002 23:01
physics project SharkBite General Forum 10 03-03-2002 22:06
MS Project Build Schedule joe_balint Technical Discussion 1 07-01-2002 03:25
