Go to Post ...many different kinds of students join our team. Some only have an interest in media, or others in cheering. What is important is that they are having fun while working in an engineering environment. - Bharat Nain [more]
Unread 02-06-2004, 16:55
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: 2 Wireless routers
Shouldn't this be in 'Technical Discussion' or something else around there?
Unread 02-06-2004, 17:34
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
It's kinda a gray area where this thread could fit. The "Technical Discussion" forum is geared towards FIRST related issues. At least in "Chit-Chat" almost anything goes that doesn't have a proper "home".
Actually if Brandon gets bored maybe he could create a subfolder in the "IT/Communications" forum for computer questions and issues. (hint, hint ) Then all these computer, networking and such threads would have a home.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 02-06-2004, 17:42
David Kelly's Avatar
David Kelly David Kelly is offline
A Legacy of Impact
FRC #0234 (Cyber Blue)
David Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond repute
Send a message via AIM to David Kelly Send a message via Yahoo to David Kelly
No, this is the correct forum for this topic.
2010 Indiana Robotics Invitational Planning Committee
2010 Boilermaker Regional
Chairman's Award, Regional Finalist
2010 Kansas City Regional
Entrepreneurship Award
2010 Championships
Autodesk Inventor Award Winner
Unread 02-06-2004, 20:46
DanL DanL is offline
Crusty Mentor
FRC #0097
DanL is just really niceDanL is just really niceDanL is just really niceDanL is just really niceDanL is just really nice
Send a message via AIM to DanL
You can't link two routers like that unless the router is specifically designed to work like that (which most consumer routers aren't).
If, on the other hand, you wanted to use that second router to extend your wireless network coverage - have two wireless routers on your network - that is possible, but you have to wire the two together. In this case, one is acting essentially as a wireless switch or hub. If you were to do this, first of all, you ignore your secondary router's (the one NOT connected to the cable modem) WAN port - connect the two using their LAN ports. Second, enable DHCP only on your primary router (otherwise, you have the two routers fighting for supremecy and you end up with problems). Disable it on your secondary router, and assign it a static ip outside your DHCP range. For example:
primary router (DHCP server): 192.168.0.1
secondary router (DHCP disabled): 192.168.0.2
DHCP range: 192.168.0.100 - 192.168.0.105
Again, this isn't what you're looking for since you have to physically connect the two routers, but if you want to extend your wireless network using the second router as a wireless switch, this is how you do it.
Wireless Security Hints:
1. When using DHCP, don't make the ip range any longer than it needs to be - i.e. if you have two computers at your house, make the DHCP range contain 3 addresses. The logic behind this is its one way to stop the casual wireless network sniffers while leaving some room for expansion (i.e. friend brings his laptop over). And wireless network sniffers aren't an urban-only problem... even in suburbia, bored techies drive around aimlessly looking for open networks (trust me - my brother has successfully done it)
2. Change your router's password from the default - any hacker worth the title knows all manufacter's default passwords
3. Change your wireless configuration's default password (depending on the make, you may not have a seperate password for wireless settings)
4. Enable atleast basic WAP again, to stop the casual network sniffer
Dan L
Team 97 Mentor
Software Engineer, Vecna Technologies
Wireless network at compitition. ArJubx General Forum 37 17-03-2004 08:52
Wireless network at GLR? TravisCarpenter Regional Competitions 1 03-03-2004 01:18
Q&A Discuss: wireless camera CD47-Bot Extra Discussion 3 16-01-2003 18:09
wireless camera Stephen P General Forum 1 11-01-2003 13:58
Did you use the 802.11b wireless LAN at EPC@T? soap108 Championship Event 21 04-01-2003 11:03
