Go to Post FIRST is supposed to prepare you for a focused career in your subject of interst, and help you manage your time and resources effectively. - Eugenia Gabrielov [more]
Unread 29-03-2002, 02:44
Jay Lundy Jay Lundy is offline
Programmer/Driver 2001-2004
Jay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to all
Problem with OI / RC
During inspection at Cleveland, we were asked to show that we had our team number set correctly on the oi and rc. However, we were unable to show them because it only displayed ---. This was strange because last year we used the same dipswitch sequence (I'm sure of it) and we remember being able to read 254 when it displayed the team number.
After playing around some more with the dipswitches, I realized that whenver the far left dipswitch is in the off position, it displays --- no matter what your team number is, and when it is in the on position it displays the team number correctly. Since the far left dipswitch represents the number 1, and our team number is an even number, we cannot get 254 to display with this switch set on.
The inspector still did not want to pass us, so we had someone from innovation first come over to check it out. He said he had never seen it before and that he would look into it.
Another interesting note, we are still not sure whether it is the rc or oi that is having the problem. We are currently using the 2002 oi and rc, but thinking that the 2002 oi was bugged we hooked up our spare one that had been used in 2001. I know this oi displayed the team number correctly on last years robot, but it also had the same problem. This led me to believe that it was actually something wrong with the rc and not the oi. This was all explained to the the innovation first guy.
So, has anyone had any similar problems? If this turns out to be a defective oi or rc, this should affect every even-numbered team in the country.
Unread 29-03-2002, 08:08
FRC Key Volunteer Trainer
AKA: CrazyNate
Without an OI to look at in front of me, my memory tells me that the far right dipswitch is the LSB, meaning that far right would = 1 and not far left. The display issue that you describe sounds like the default behavior when the OI is set to a team # greater than 999. I would double-check all of your dipswitch settings, even to the point of setting it so the system displays 0 and adjusting from there. I know we(team 470) did not run into this problem when we were setting our team #.
Nate Smith
nsmith@smythsoft.com
Unread 29-03-2002, 23:07
Well I know our team number is set to 254 and when I switch the far left switch it changes to 255. Maybe there's something messed up with the entire dipswitch panel on our oi. The guy from innovation first confirmed we had the right sequence.
I myself actually thought that the dipswitch that represents the number 1 was supposed to be on the far right, but this is how ours works.
Victor problem Andy Baker Electrical 15 24-06-2003 09:49
Ok one problem cantwell03 Programming 3 13-02-2003 07:28
The problem with scouting... archiver 2001 10 23-06-2002 23:49
joystick problem archiver 2000 12 23-06-2002 23:08
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
