Go to Post More to the point, stop worrying about whether your "Atlanta bot" got screwed over or whatever. Worry about whether you've got an "Atlanta team." - RebelWithARobot [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 05-06-2004, 11:57
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Question Code Print
Does anyone know how to get multiple code files to a single PDF?
What I'm hopping for is to be able to save a bunch of different code files (PIC C), where a new file begins a new page, and preferably with syntax coloring. Help?
Unread 05-06-2004, 12:33
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: Code Print
I don't know much about it, but I know this would be possible with PHP. That would be look too, because then it could be something available to everyone if you want it to be.
Unread 05-06-2004, 12:36
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: Code Print
It would be pretty easy in PHP thanks to PDFlib functions.
Team 1257
Unread 05-06-2004, 12:40
mtrawls's Avatar
mtrawls mtrawls is offline
I am JVN! (John von Neumann)
#0122 (NASA Knights)
mtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to behold
Send a message via AIM to mtrawls
Re: Code Print
Well, do you have just the Acrobat reader program? Assuming this is the case ... you might try PDF::Create, a perl module. This way you could loop over all the files you wanted and harness perl's text processing ability to add syntax highlighting yourself (if desired). Also, OO.o will export to PDF.
Unread 05-06-2004, 13:29
AKA: Jamie Bliss
Re: Code Print
I'll try that. I don't actually know pearl, but my dad does, so I'll ask him.
I do have PDFwriter (Adobe's PDF print driver), but the problem is that I can't find an editor that will print several files at once.
So far, the best solution I have found is to print them one at a time, open the results, copy them into Word, respace it, and then print it out again. Quite labor intensive. I tried to find an HTML type printer, but no luck (HTML would be easy to append).
Unread 05-06-2004, 17:18
Fold em oval!
Re: Code Print
Why do you print them to PDFwriter first? To save the color coding? There are dozens of text editors with syntax highlighting. I'm sure some of them will let you copy with color in tact. There is a thread listing a dozen or so (I think you posted in it, so I'm sure you know).
I'd still do it in PHP (or Perl). If you do it in PHP, use SilverStar's C highlighter at http://nrg.chaosnet.org.
Team 1257
What is your most prefered programming language? Hailfire Programming 156 19-01-2005 21:42
Interrupt timer, executing code asap? SeanCassidy Programming 10 07-03-2004 01:47
Does your team use the Default code. Jeff McCune General Forum 2 09-01-2003 14:46
