Go to Post One last thing, if a mechanical part fails on you, sometimes you can get a little bit of noise back into it by yelling at it, kicking it, or pounding on it with your fist. This might put enough back into it so it will work for a few more minutes. - KenWittlief [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 07-06-2004, 18:22
indieFan indieFan is offline
RoboDox and LVHS - Missing you!
FRC #5941
indieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond repute
Calc. Triangle Angle or Side Based on Ellipses?
Hi Everyone,
I'm currently working on coding a program for a CNC using variables. I've run into a significant stumbling block regarding the math, however.
I am taking two ellipses that have every point the same distance apart. I then have a known starting angle; and, because the ellipses are to be symmetric about the x-axis, the finishing angle. Once the program reaches the finishing angle on the outer ellipse, it is to move inward at the same y position to the inner ellipse. (Essentially, it is cutting out the letter C.)
Here are the questions:
1. How does one tell when one is on the inner ellipse?
2. Is it possible to calculate the new x length given only the y dimension?
3. Is it possible to calculate the new angle given only the y dimension?
My test numbers (in inches) have been:
Major (y) axis: 6; Minor (x) axis: 4; start angle: 15; distance between ellipses: 0.5
If it still isn't clear, please let me know.
Any help would be appreciated,
indieFan
P.S.- I may have figured it out:
Knowing that the y-distance from the x axis is -0.5275 at the end, and that the total y length from center to end of the axis is 2.5, then the new angle can be calculated using asin(-0.5275/2.5)=theta. Theta is equal to -12.18 degrees. Given theta and the y length, the x distance can now be calculated since the distance from the center to the x-axis is known.
The new problem is how to calculate an asin when there is no function available in the programming language. :-(
P.P.S.- I think I finally understand the arcsin(x)=arctan(x/sqrt(1-x^2)) equation which is easy to program.
Unread 07-06-2004, 21:25
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
Re: Calc. Triangle Angle or Side Based on Ellipses?
trig substitution.
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Angle from X,Y Astronouth7303 Programming 18 19-04-2004 22:08
