Go to Post Words mean what words mean. If your robot is sitting on the ball, then by definition it is not hanging from the bar. NO 50 point bonus. - dlavery [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 10-06-2004, 18:32
Joshua May's Avatar
Joshua May Joshua May is offline
Go Bears!
FRC #1110 (Binary Bulldogs)
Joshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond repute
Send a message via AIM to Joshua May
PHP Question
I am currently working on a news posting script for my team's site using PHP. I've got everything down for posting and adding news, but I need a way to have only the most recent posts added. I tried to create a while loop so that only the 5 most recent posts show on the index page, but it didn't work. If anyone can help me figure it out, help would be greatly appreciated. And i simplified the part of the code that displays the post.
PHP Code:
$data
file('news.txt');
$data array_reverse($data);
foreach(
$data as $element) {
$element trim($element);
$pieces explode("|"$element);
    echo
$pieces[0] . $pieces[1] . "\n";
    echo
"<hr>\n";
The FIRST Wiki - openFIRST - Ultimate Robot Challenge - URC Wiki
I currently have 50 GMail invites, PM or email me for one.
UC Berkeley Class of 2009
2005 Las Vegas Regional Autodesk Visualization Award
2005 Las Vegas Regional #8 Seeded Alliance with 988 and 1505
2006 Southern California Regional #15 seed
Unread 10-06-2004, 19:07
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: PHP Question
I'm not sure exactly how your code was intended to work, but it appears that you check each line of news.tct for "|" which are used to divide that line into two parts ($pieces[0] and [1]) that are then just outputted concatenatedly so the output is just the text without the pipes. I think maybe you intended "|" to seperate different entires but you didn't realize that file() reads each line into a new element in the array.
Team 1257
Unread 10-06-2004, 19:52
Raven_Writer's Avatar
Raven_Writer Raven_Writer is offline
2004 Detroit & Pittsburgh Winners
AKA: Eric Hansen
FRC #0005 (RoboCards)
Raven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really nice
Send a message via ICQ to Raven_Writer Send a message via AIM to Raven_Writer Send a message via MSN to Raven_Writer Send a message via Yahoo to Raven_Writer
Re: PHP Question
If at all possible, would you be able to use a database like MySQL?
If not, then why not just write the newest news information at the top of the file? I believe there's a way to set the file pointer to the beginning of the file before you write.
(I can't supply code for doing the file stuff...I've had issues with doing that in the past)
AIM: wisprmylastbreth
EMail: nightskywriter@gmail.com
Y!: synsoflife
"ai yoru ga" -- "Love the nights"
Unread 11-06-2004, 15:42
Joshua May's Avatar
Go Bears!
Re: PHP Question
Sorry that I didn't elaborate on that, the file news.txt which contains all of the news looks like this:
Date|Poster's Name|News Title|News Story
And yes, the | is used to separate each section.
I do have access to three MYSQL databases, but I haven't yet learned how to interface with MYSQL yet. Also, I use the array_reverse() function to read the newest news from the top of the file, I just need some way where I can just get the newest five stories to display.
Unread 11-06-2004, 15:49
AKA: Eric Hansen
Re: PHP Question
Hm...maybe seperate each item by underscores or something, and scan the file for it, and each time it's found, fill an array w/ the info and also use a counter. An example:
PHP Code:
// number of news items read
$num_news 0;
// global array defined here
// open file for reading
$file fopen("news.txt""r");
// read file
$stuff fread($file);
// loop through the reading
while(($num_news 5) && ($stuff != eof())){
/* store news items in an array...I'm not sure on howto do this, so... */
Y!: synsoflife
Unread 11-06-2004, 16:25
Joshua May's Avatar
Go Bears!
Re: PHP Question
Thanks, I'll try that, really the while(($num_news < 5) && ($stuff != eof())) is what I was looking for, just not really sure where to put it in the code.
EDIT: I've got it, rudimentary as it is:
PHP Code:
$counter
0;
$data file('news.txt');
foreach(
$data as $element)
if(
$counter 5)
      echo
$pieces[0] . $pieces[1] . $pieces[2] . $pieces[3];
      echo
"<hr>\n";
else
$counter $counter 1;
Unread 11-06-2004, 20:37
Joshua May's Avatar
Go Bears!
Re: PHP Question
Now I have a new question. I have set up a user authentication page, which asks for a username and password. If the correct username and password are given, I want the browser to redirect to a certain page. Hwoever, I don't know the PHP function (if there is one) that will redirect to a new page. I've searched around but I can't find anything.
Unread 11-06-2004, 20:46
AKA: Eric Hansen
Re: PHP Question
Here's some code to do it:
PHP Code:
// ** BELOW CODE ABOVE THE <HTML> TAG!! **
$log $_POST['login'];
$user $_POST['username'];
$pass $_POST['password'];
if((
$log) && ($user == /* stored username */) && ($pass == /* stored password */)){
header('Location: http://the.address.to.the.redirection.com');
} else{
// login script
$log = $_POST['login']; - this is storing the value of "login" in a variable "$login". login is the name of the submit button of the form.
$user = $_POST['username']; - stores the entered username (in the textbox) into a variable. username is the name of the textbox.
$pass = $_POST['password']; - same as above, but subtitute the obvious.
The reason for having the if(...) case above the <HTML> tag is because since <HTML> is a header, you can't send a header after a another header (it's hard for me to explain, so just look up the "header()" function in the PHP doc.).
Your form should look something like this (assuming the form is located on a page called: "login_admin.php"):
<form action="login_admin.php" method="POST">
<input type=text name=username><br>
<input type=password name=password><br>
<input type=submit name=login value="Login">
</form>
Y!: synsoflife
Unread 11-06-2004, 20:49
Joshua May's Avatar
Go Bears!
Re: PHP Question
Thanks Raven_Writer, for all your help.
Unread 11-06-2004, 20:50
AKA: Eric Hansen
Re: PHP Question
No problemo.
I've been doing this kinda thing so many times, I've got it all memorized. lol.
Y!: synsoflife
PHP Question Raven_Writer Website Design/Showcase 2 22-05-2004 18:42
Question of the Week [05-02-04]: The Very Merry Month of May EddieMcD Rumor Mill 10 05-05-2004 14:02
A question about control system options computhief263 Control System 7 04-02-2004 14:46
What's better, PERL/cgi or PHP/my_sql? mikefrei Programming 10 27-05-2002 22:50
