Go to Post Has anybody seen our programmer? He was last sighted walking southbound in the rain, his laptop tucked under his arm, grumbling to himself. - Taylor [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 11-06-2004, 19:45
Raven_Writer's Avatar
Raven_Writer Raven_Writer is offline
2004 Detroit & Pittsburgh Winners
AKA: Eric Hansen
FRC #0005 (RoboCards)
Raven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really nice
Send a message via ICQ to Raven_Writer Send a message via AIM to Raven_Writer Send a message via MSN to Raven_Writer Send a message via Yahoo to Raven_Writer
Using Linux?
I have a question about using Linux:
How dangerous is it to have a computer dual-boot Linux and WinXP?
I'm thinking of trying to convince my mom to let me do this, and am wondering if there's any major (or even minor) things that could happen, and ruin the computer. I know there's virii out there, and stuff like that, but I mean just have Linux itself reformat the drive (just for an example).
AIM: wisprmylastbreth
EMail: nightskywriter@gmail.com
Y!: synsoflife
"ai yoru ga" -- "Love the nights"
Unread 11-06-2004, 20:02
Venkatesh Venkatesh is offline
FRC #0030
Venkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to behold
Re: Using Linux?
Its almost completely nontoxic. There isn't even industrial chemical residue from trying to mix Linux and Windows XP. =)
The greatest dangers appear during the install of Linux. Many people without experience (or with experience but were careless) wiped out their Windows partitions.
-- vs, me@acm.jhu.edu
Mentor, Team 1719, 2007
Team 30, 2002-2005
Unread 11-06-2004, 20:03
AKA: Eric Hansen
Re: Using Linux?
Got any resources on doing this by any chance? (Just even in general of doing dual-booting)
Y!: synsoflife
Unread 11-06-2004, 20:05
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: Using Linux?
If you have a decent about of knowledge of disk partitions, you should be fine. Depending on which distro of Linux you are installing, you might have to use fdisk, which can be hard if you haven't used it before. If you are using one of the bigger ones, such as Redhat/Fedora, Mandrake, etc, you should be fine. Feel free to PM me/IM me if you need help. I've at least attempted to get many of the larger distros working.
--EDIT--
In response to your last post, try Redhat.com. I'll look for a the address here and see if it is still up...
Here you go: https://www.redhat.com/docs/manuals/...titioning.html
Probably focused on Redhat mostly, but it should give you the idea...
-----EDIT-------
I don't know what distro you are installing, but know that most can't resize NTFS partitions (what XP is on). If you download the first ISO for Mandrake, you can resize them. I've never had a problem with it.
----EDIT------
Better than the last URL: https://www.redhat.com/docs/manuals/...artitions.html
Unread 11-06-2004, 20:16
mtrawls's Avatar
mtrawls mtrawls is offline
I am JVN! (John von Neumann)
#0122 (NASA Knights)
mtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to behold
Send a message via AIM to mtrawls
Re: Using Linux?
That's not what Bill would have you believe!
Unread 11-06-2004, 20:17
Programming User
Re: Using Linux?
That's great! I don't know how they "figured" that out... Weird.
Don't believe a word of it.
Unread 11-06-2004, 20:39
AKA: Eric Hansen
Re: Using Linux?
I'm not. Even if that were true, I wouldn't care. I don't like Windows at all. It is good for some things, but I just prefer *nux O/S's anytime over Windows.
Y!: synsoflife
Unread 11-06-2004, 20:40
Re: Using Linux?
The most important question is, how many times have you installed linux before? Unless you've installed it a few times before, I wouldn't recommend you do it to your mom's computer.
Also, you should make a full backup, while it's normally quite safe, you don't want your mom killing you if something goes wrong.
Finally, there are some issues with the 2.6 kernel that can cause corruption of the XP partition table. http://slashdot.org/articles/04/05/2...id=110&tid=187. Definetly make sure that whatever distro you chose has fixed (or uses a 2.4 kernel).
Unread 11-06-2004, 20:48
AKA: Eric Hansen
Re: Using Linux?
Joe:
I've never installed Linux before ( :\ ). I've only used LiveCD versions of it (ala Knoppix).
I would always make a backup disc of my computer anyways. That way my mom doesn't blow up worse than an a-bomb.
I'll check to see what kernel the distro. I choose uses.
Thanks a lot also for your input
Y!: synsoflife
Unread 11-06-2004, 21:11
opnickc's Avatar
opnickc opnickc is offline
AKA: Nick
FRC #0067 (H.O.T.)
Team Role: Animator
opnickc will become famous soon enoughopnickc will become famous soon enough
Send a message via AIM to opnickc
Re: Using Linux?
I currently dual-boot Windows ME and 2000prof. I've never installed linux, but i know that windows 2000 (and probably XP) will recognize a previous OS and give you an option of which system you want to boot to when you start up. The only catch is, you have to install 2000 after the other OS, so you'd have to backup your system and reinstall eveything. Not a big deal, but then again I don't know if this will work with Linux or Windows XP. Good luck.
2005 - H.O.T.'s best year ever!
GLR Champions (thanks 66 and 68)
-Delphi Driving Tomorrow's Technology Award
Buckeye Champions (thanks 279 and 274)
West Michigan Regional Chairman's Award
Newton Division Champion (thanks 330 and 503)
Championship Winner (thanks 330 and 503)
Championship Chairman's Award Winner
The only team to win the Chairman's Award and the Championship, not to mention in the same year.
(please correct me if I'm wrong)
Disclaimer: The views expressed in this post are solely those of the poster and do not reflect the opinions of team 67, FIRST, or any affiliate or subsidiary of the two.
Unread 11-06-2004, 21:18
AKA: Eric Hansen
Re: Using Linux?
Thank you. So, basically what you are saying is that when you installed Windows ME over Win2k Pro (or vice-versa), you had to reinstall the origional operating system?
Y!: synsoflife
Unread 11-06-2004, 22:11
Marc P. Marc P. is offline
I fix stuff.
AKA: βetamarc
Marc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond repute
Send a message via AIM to Marc P.
Re: Using Linux?
There are many key differences in multi-booting between various versions of windows and booting between windows and linux. Most windows systems can utilize the same file system (fat32), and as such, not much must be changed on the hard drive to get them to work with each other. Linux, however, is a whole differant animal. For most distributions you will have to repartition your hard drive (to ext2/ext3, reiser-fs, etc) or install to a different hard drive, both of which could potentially be hazardous to windows if not done carefully. The master boot record of the primary drive would have to be changed to allow the new system to boot, which isn't too difficult- especially in modern distributions. However, should something go awry, it could prevent windows from booting. Make sure you read all documentation before you install, and read all prompts and warnings that should come up during the install.
The one thing I've found about most linux communities, is they are usually very open and helpful should you run into trouble. Linux is a great system to run, and very satisfying once you get into it. Good luck with the installation!
Unread 11-06-2004, 22:30
Re: Using Linux?
There is a big difference in the assumptions that windows 9x (including ME), Windows NT (including 2000, XP, and 2003), and linux make when installing.
When Windows 9x installs, it assumes it is the only operating system. It must be put in the first primary partition on the hard drive, and overwrites the MBR with its bootloader. If you have another OS in the first primary partition, it will be overwritten. Even if your OS is in a different location, the MBR will be overwritten and you won't be able to boot into it.
When Windows NT installs, it looks for other Microsoft operating systems, but ignores others, like linux. It can be installed in other partitions. If it sees another windows operating system, it will include options for it in its bootloader. You can even modify the bootloader to load the linux bootloader.
Most linux distributions can be installed anywhere on the disk, and will include options to any other OSes in the bootloader (in fact, they are much more likely to miss other linux installations then windows installations). I've always used the linux bootloader (both lilo and grub) to load windows 2000, but there are people who swear by using the windows bootloader to load linux.
Unread 11-06-2004, 22:57
AKA: Eric Hansen
Re: Using Linux?
Does anyone here use a liveCD (namely Knoppix)?
Y!: synsoflife
Unread 11-06-2004, 23:10
JakeGallagher's Avatar
JakeGallagher JakeGallagher is offline
Mmmm Hot Sauce
#0134 (Team Discovery)
Team Role: Operator
JakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant future
Send a message via ICQ to JakeGallagher Send a message via AIM to JakeGallagher Send a message via MSN to JakeGallagher Send a message via Yahoo to JakeGallagher
Re: Using Linux?
I had one problem when i was trying to run Redhat 7.3...i got it installed, but my video drivers weren't compatable and so I had someone uninstall it, but it was apparently labeled as the primary boot partition, so my Windows partition was almost lost.
My friend runs Fedora and WinXP Pro on his laptop and it works fine, though. He hasn't had any trouble at all with either of them.
Just make sure you know what you're doing when you get into Linux (especially if you're working on your main machine).
I haven't updated my signature since last May. Who wants to suggest a replacement?
Linux SteveC116 3D Animation and Competition 22 25-03-2004 15:07
Linux: steps to program fullsize RC robot rwaliany Programming 31 14-02-2004 14:45
Linux And Windows XP Raven_Writer Chit-Chat 4 06-08-2003 18:53
RoboEmu for Linux (PBASIC emulator) rbayer Programming 5 21-11-2002 21:08
Linux file extensions rbayer CD Forum Support 5 14-11-2002 23:04
