Go to Post I think that one of the most fantastic parts about FIRST is that the biggest and most successful teams are also the most abiding to the rules. - Matt Adams [more]
Unread 14-06-2004, 08:07
cmaccoy's Avatar
cmaccoy cmaccoy is offline
FRC #0173 (R.A.G.E.)
Team Role: Student
cmaccoy is on a distinguished road
Send a message via AIM to cmaccoy Send a message via Yahoo to cmaccoy
Re: What to machine?
Originally Posted by sanddrag
Well, I did that last January and Februrary Anyway, I have designed the 2005 drive (6 motor 2 speed) but it requires at least 3 CNC parts per gearbox. I know how to set up and run the CNC but not how to make the program with MasterCAM. I want to do mostly manual work. I could change the shifting dog to a design that is manually machinable but it would not be as good or as trick. Plus without a robot to put it on, what am I going to do with it. I looked under the hood of my truck to see if there was anything I could replace with a machined part but didn't find much other than making a cold air intake which isn't well proven to do much of anything in the way of HP. I spent a while underneath my truck and same story there. Much of the stuff on cars these days is so advanced you can't easily make a replacement part. One thing I could make is a custom aluminum driveshaft but there is no reason.
Any other ideas?
If you think it would help, i could show you somewhat how to run MasterCam. For one, you can go to File, Get, then Samples, just to get a small insight in what MasterCam can do.
~cmaccoy
F.I.R.S.T. My anti-drug
which button machine do you use and do you like it? KenWittlief General Forum 10 16-10-2003 00:01
machine shop?? trollin1st Off-Season Events 0 12-02-2003 21:02
Choosing a machine shop (Re: How important is a machine shop archiver 2001 9 24-06-2002 04:20
The Brazilian Machine on a Fire Truck Digo General Forum 10 08-04-2002 01:36
