I'm using the Joystick API to get info on joysticks. The problem is that even though it claims to have a joystick, it says that it has no axis. Which indeed would seem to be the case: it seems to have a joystick w/o any axis or buttons. I have one plugged in, and it seems to work. I attached the module in question. Help?
They idea is that you call InitJoystick(), then you call GetPos() to update X, Y, and Z. |
| Problems hooking up a joystick to edubot | Salik Syed | Programming | 2 | 24-03-2004 23:56 |
| Changing 1 joystick code to 2 (rookie team) | Brawler006 | Programming | 5 | 20-02-2004 17:00 |
| robot goes haywire with the one joystick default code | Miles | Programming | 7 | 24-01-2003 14:58 |
| joystick problem | archiver | 2000 | 12 | 23-06-2002 23:08 |
| switching joystick axis????? | team222badbrad | Technical Discussion | 9 | 16-01-2002 23:07 |
