Go to Post Once you go to your first (FIRST) competition... thats when you fall in love with it. - Jaine Perotti [more]
Unread 16-06-2004, 17:55
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: Failed attempt at simulation
Unread 16-06-2004, 17:58
mtrawls's Avatar
mtrawls mtrawls is offline
I am JVN! (John von Neumann)
#0122 (NASA Knights)
mtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to behold
Send a message via AIM to mtrawls
Re: pic: Failed attempt at simulation
I suppose I should explain a bit about the picture. At the point in the project when this particular screenshot was taken, I had been working to scale back the model of the playing field to remove unnecesary items so that it would load quickly. Realistic display and real time play often are at direct odds with each other, so I was experimenting with various display methods (hence the wierd graphics). Also, this particular shot is one where I was populating the field and seeing how all the elements would interact. If anyone has questions, PM me (I think I might be able to pull up the paper I wrote, if anyone is interested).
Unread 17-06-2004, 06:33
how do you throw the balls into the goals?
Unread 17-06-2004, 06:58
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
It does indeed inspire me...
Not bad actually.
Unread 17-06-2004, 09:24
mtrawls's Avatar
Well, you don't! The robot actually did have a mechanism for it, but this is a much scaled back version I used for debugging purposes because it loaded much quicker. The physics support in CS was just beginning at that time, though, and there were quite a few glitches. Trying to move a ball with the robot created an inconsistent system, and all sorts of wierd things happened. I was in almost constant contact with the mailing list, and actually convinced someone to start working on ODE support ... but it didn't come quick enough for my project (and I don't know where it is now, this was 2 years ago).
Unread 17-06-2004, 11:03
looneylin's Avatar
looneylin looneylin is offline
I'm rad. U're rad. Let's hug!
AKA: Alicia Lin
FRC #0433 (Firebirds)
Team Role: Webmaster
looneylin has a brilliant futurelooneylin has a brilliant futurelooneylin has a brilliant futurelooneylin has a brilliant futurelooneylin has a brilliant futurelooneylin has a brilliant futurelooneylin has a brilliant futurelooneylin has a brilliant futurelooneylin has a brilliant futurelooneylin has a brilliant futurelooneylin has a brilliant future
Send a message via AIM to looneylin Send a message via MSN to looneylin
Talking Re: pic: Failed attempt at simulation
it's not that bad...keep meddling
Tycho Brahe's the man. lol
pic: Panoramic Pic from Nationals 2001 CD47-Bot Extra Discussion 19 23-03-2004 23:38
pic: Team PIC of 354 Westinghouse HS CD47-Bot Robot Showcase 4 29-02-2004 12:15
pic: pic 1 CD47-Bot Robot Showcase 6 22-02-2004 00:29
pic: Team 1053's very first ever teaser pic CD47-Bot Robot Showcase 3 16-02-2004 22:56
Team #237 2001 Robot - "Nineteen foot six" archiver 2001 13 24-06-2002 00:59
