Go to Post The problem is though, as long as the teams are allowed to work on their robots on Thursday, they will, and they'll never learn to finish it before the event. - sanddrag [more]
Unread 18-06-2004, 13:42
DKolberg DKolberg is offline
Mentor Iron Giants
AKA: David Kolberg
FRC #5069 (Iron Giants)
DKolberg has a spectacular aura aboutDKolberg has a spectacular aura about
Lightbulb Re: (Experimental) PID Control System
The OI does know what state it is in. It knows when it is in competition mode, disable mode, or autonomous mode. Your control loops should be aware of which state the sytem is in and provide code for transitioning between each state. You can use different controls for each state, but anything with memory like integrators should be delt with as the system changes from state to state. All memory type variables should be initialized to a known state while not being used in a specific state so it is ready to be used when the new state starts.
What do you wish you knew about the new control system? Joe Ross Control System 2 09-01-2004 21:47
Need a FIRST Robotics control system kershawrobotics General Forum 3 07-07-2003 09:49
control system worth more than $500 archiver 2001 8 24-06-2002 02:00
New Innovation FIRST control system and the dashboard archiver 2000 0 23-06-2002 22:15
Ok, how much is the control system worth? archiver 2001 6 23-06-2002 22:05
