Go to Post Being a mentor only requires an open mind and fifty thousand times more responsibility. - Amanda Morrison [more]
Unread 31-03-2002, 17:57
geo's Avatar
geo geo is offline
A Nuke Would Do The Job!
FRC #0865 (WARP 7)
geo is a jewel in the roughgeo is a jewel in the roughgeo is a jewel in the roughgeo is a jewel in the rough
Lightbulb I am wondering...........
Is it necessary to put two pressure switch on the pneumatics system or just one?
Unread 31-03-2002, 18:47
Jay Lundy Jay Lundy is offline
Programmer/Driver 2001-2004
Jay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to all
One is enough.
Unread 31-03-2002, 19:18
RebAl's Avatar
RebAl RebAl is offline
ISee It When I Believe It
None #0329 (The R.A.I.D.)
RebAl will become famous soon enough
Send a message via ICQ to RebAl Send a message via AIM to RebAl
But 2 is necessary to have a efficent system, one set to system low and another set to system high, this will prevent unecessary cycling of the pump, and save some breakers
Unread 10-04-2002, 13:58
AdamT's Avatar
AdamT AdamT is offline
#0401
AdamT is on a distinguished road
You can and according to the manual, you should put two on...one for each accumulator. You run it so that the 115 psi switch is on the first accumulator on the line, and 110 on the second. You then program it so that when it sets off the 115 psi switch, the pump turns off, then when the 110 psi switch is released, the pump starts back up...
I would also pre-pressurize the tanks before matches.
~Adam
Unread 10-04-2002, 14:44
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
1 switch + delayed turn off code
I don't thinks the switch is required. Also, you don't necessarily need to have 2 switches to have an efficient system.
It is possible to write code that runs the pump for XXX seconds after the switch is made. We set the switch to 100 psi or so. Then we measure how long it takes the pump to get to 120 psi after the switch makes its transition to indicate the pressure is above 100 psi. We then use the delayed turn off code to keep the pump running until the pressure is at 120 psi.
Joe J.
Unread 10-04-2002, 14:45
One of the top robots at the Canadian Regional (who only received ONE switch) have the switch show the operator (via the SW1 LED on the OI) when the pressure is low, and then he holds a button down until the light goes out.
I had shown them the code for counting time that we used last year, but they simplified it some :-) .
"Uncomplicated may win !" parlayed the paraphrased playful Pappalardo Professor.
Unread 10-04-2002, 14:57
AdamT's Avatar
#0401
I dunno, our method didn't seem too complecated to me, and there's no guesstimating and operator involvement....i like those ideas though.
~Adam
Unread 12-04-2002, 17:54
The Lucas's Avatar
CaMOElot, it is a silly place
One Switch Debounce
You could set the one switch to 120 psi. Then use the program to debounce the pressure switch. When the switch first indicates that the pressure is at 120 or above, use a counter variable to wait 1 sec (roughly 40 cycles of the main loop) before turning the pump off. Use the same delay before turning on the pump after the pessure drops below 120.
Robot Inspector
Unread 15-04-2002, 08:48
Jim Meyer's Avatar
Jim Meyer Jim Meyer is offline
Engineering Mentor
None #0067 (HOT)
Jim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond repute
Two Switches Makes it Easy....
The benefit of having two switches is ease of programming. With them both connected to the accumulators, if you set one at 120 psi and the other at 100 psi you can program the compressor to turn on when the pressure dropps below 100 and shut off when the pressure gets to 120 psi. This way you don't have to do any "debouncing".
Last year we had problems blowing fuses on the spikes if we turned the compressor on with an accumulator pressure at 120 psi. It didn't happen very often but I believe it is good practice to not turn your compressor on unless the accumulator pressure is less than 100 psi. The easiest way to do this is with two switches. The method Joe J. mentions is also a good one but is probbably a little trickier to program. The method described by "The Lucas" allows the compressor to turn on at high pressures if you have a slow leak or a small cylinder.
Unread 15-04-2002, 11:18
asher asher is offline
None #0031
asher will become famous soon enough
the less our driver has to think the better, 2 switches is what we feel is best, no thinking required.
Unread 15-04-2002, 13:17
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
Exclamation One is good enough ....
We use the one switch + delay that Joe mentioned. It works fine, less parts, one less input, and the code is easy enough.
Prior to this year, we only had the one switch to work with. It's one of those "It ain't broke - don't fix it" things for us.
Ed Sparks
MECH TECH FRC-3959
just wondering..(sensors) JasonStern Electrical 14 08-05-2003 00:16
just wondering robomama Chit-Chat 26 23-07-2002 23:44
ANTI-MATTER, i was wondering... archiver 2001 2 24-06-2002 01:15
I was just wondering about FIRSTanimators and Chiefdelphi Robby O CD Forum Support 2 25-01-2002 00:19
I am wondering what kind of jobs the adults have... Ken Leung Career 15 23-07-2001 15:19
