Go to Post Awesome doesn't even scratch the surface here folks. - DonRotolo [more]
Unread 17-06-2004, 14:12
indieFan indieFan is offline
RoboDox and LVHS - Missing you!
FRC #5941
indieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond repute
Image Capture for Real Player?
Does anyone know if it's possible to capture an image from a Real Player movie using nothing more than Paint (from the accessories menu) in Windows? Installing other programs is not an option.
Thanks,
indieFan
Unread 17-06-2004, 14:37
George1902's Avatar
George1902 George1902 is offline
It's a SPAM thing...
AKA: George1083; George180
FRC #0180 (SPAM)
George1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond repute
Re: Image Capture for Real Player?
Originally Posted by indieFan
Does anyone know if it's possible to capture an image from a Real Player movie using nothing more than Paint?
I'm not the most computer savvy person around, so I apologize in advance. You might be able to use the screenshot function to get a still image.
Try pausing RP at the image you want. Then hit the "Print Screen" button on your keyboard to take a screenshot. Open Paint and paste the screenshot in. You should be able to take away everything except that piece you want.
Hope that helps.
George
"Darkness cannot drive out darkness; only light can do that. Hate cannot drive out hate; only love can do that."
-- Martin Luther King, Jr.
Unread 17-06-2004, 14:48
FRC #5941
I had tried the "print screen" method before posting previously. The image does not seem to be transferred correctly.
Thanks anyway,
indieFan
Unread 17-06-2004, 15:00
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
RealPlayer deliberately blocks <Alt>+<PrtScn>, and various such things. You might have better luck with an image-capture option like the one in Paint Shop Pro. (File | Import | Screen Capture, if I'm not mistaken.) Photoshop ought to be able to do this too.
Unread 17-06-2004, 15:35
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Hmm... Unless Real hooked the message, that may mean the Real uses an overlay (like your cursor), which is not captured by PrtScn (alt or otherwise).
Is this RealOne or an older version?
Unread 17-06-2004, 15:40
FRC #5941
I tried the print screen command again holding down the alt key, and it grabs the image. However, the information that is stored in the previous image of the two that I did, has changed from the original to that of the second screen shot.
Thanks again,
indieFan
P.S.- This is version 6.x
You are correct, Real does use an overlay. However, at least in older versions, you make it so it doesn't use one by fiddling with the video settings.
Unread 17-06-2004, 15:58
AKA: Jamie Bliss
On v6, the only option that appears to be remotely right is under the Performance tab, "Use optimized video display".
Unread 18-06-2004, 00:54
DanL DanL is offline
Crusty Mentor
FRC #0097
DanL is just really niceDanL is just really niceDanL is just really niceDanL is just really niceDanL is just really nice
Send a message via AIM to DanL
I tried researching this, and in short, I found the answer to be this isn't possible. It seems whenever you try and grab a screenshot, it gets you just a blank screen. It wasn't clear whether this was intentional or just a result of the way the video is decompressed/played, but the analogy that stuck with me best is that of a projection screen; you can see the video, but if you try and take a picture of it with your camera, the flash results in you getting nothing. Just about every video player - Windows Media, DivX Player, DVD software - does this, so thats what leads me to the intentional vs. non-intentional debate.
Anyways, I know that some DVD playing programs have specific screen capture features. My guess is because the formats are open, its possible to write code to save the frame as an image rather than display it on the "projection screen." Real uses a proprietary closed format, though, so I don't think you'll find much luck finding a program that does this for Real videos.
Dan L
Team 97 Mentor
Software Engineer, Vecna Technologies
Unread 18-06-2004, 13:14
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Try this very interesting experiment. (It won't get you what you want, but it's very interesting, and it might spark an idea in someone's head about how to actually get a screen shot.)
  1. Play your video in Real Player.
  2. Press Alt-PrtSc to capture the Real Player window image.
  3. Paste the captured image into Paint.
  4. While the video is still playing (or play it again, if you need to), position the Paint window so that the region of the Paint window where the video image would be is over the Real Player window.
What you'll see is the video playing in Paint!
Another interesting thing: As I was looking for a video to play in Real Player, I came across this video archive page for the Central Florida Regional. You'll notice that there, on the page, is a perfect screen capture of a match being shown in a Real Player window! Just a thought: Maybe NASA paid for their Real Player, and if we all weren't so cheap, we could do screen captures too.
Unread 18-06-2004, 15:35
AKA: Jamie Bliss
You could try going to full screen, then putting it on media through a recorder hooked to your computer. Then copy the media back on your computer.
Unread 22-06-2004, 17:31
LBK Rules's Avatar
LBK Rules LBK Rules is offline
1467 '06 Alumni
AKA: Anthony Rinaldi
no team (HSRO)
LBK Rules will become famous soon enoughLBK Rules will become famous soon enough
Try getting Real Alternative. That can save screen captures.
Anthony Rinaldi
Team 1132: 2003
Team 1467: 2004 - 2006
Unread 22-06-2004, 22:22
AKA: Jamie Bliss
http://www.google.com/search?q=Real+Alternative
basic stamp editor debug capture dave_l Programming 4 17-03-2003 19:35
human player pads starting Soukup General Forum 9 21-02-2003 10:12
How the heck do I do a screen capture on Real Player Elgin Clock General Forum 10 05-04-2002 03:10
Human player actions & interactions llambele Off-Season Events 3 12-10-2001 12:51
