Go to Post Neat! I like when things break, it's educational! - s_forbes [more]
Unread 23-06-2004, 19:49
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Using the TTL and program port
Now I know the gut reaction of all you good, community-minded CD users is to point me to a search of the forums for this information, but I have already done that. After spending an hour or two looking on several websites, I could not find a complete explanation of how the TTL (and program) port works and how to use it. I understand the topic might be too big for a single resource to cover it, but even an introduction is lacking. Some of the things I'd like to know are
  • what does the protocol specify (i understand it is very loose)
  • pin out chart (specific to RC/Robovation)
  • What do the functions in usart.h actually do
  • a (well) documented example of its use
Of course, you can help the whole community out by recording this information in a FIRSTwiki article about the TTL port. Thanks.
Team 1257
Unread 23-06-2004, 19:52
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Re: Using the TTL port
im guessing by ttl port you mean a computers parallel port and if thts truely what you mean then here http://computer.howstuffworks.com/parallel-port.htm
Hope that helps
-Michael Dessingue
Unread 23-06-2004, 20:06
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
I think he's talking about the TTL serial port on the EDU-RC. It should be functionally identical to a regular serial port, except with much lower voltage levels required for signalling.
Unread 23-06-2004, 20:33
AlbertW's Avatar
AlbertW AlbertW is offline
harker robotics :. 1072
AKA: Aonic
#1072 (Harker Robotics)
AlbertW is on a distinguished road
Send a message via AIM to AlbertW
He's talking about the TTL (Transistor-Transistor Logic) port on the 2004 Robot Controller.
The TTL port is a direct link to the User Processor in the RC and is basically a non-level-shifted version of the program port (which is RS232). Both of them can be used (with or without level-shifting) to communicate with other serial devices like CMUcams, computers, other RCs, and so forth.
In short, it's another serial port. How do you use it in the progrmaming? Don't ask me.
Oh, and the pinout (as copied from the Innovation FIRST RC reference guide) is
From left to right, +5v, TX (transmit), RX (recieve), B (ground)
We were the first seeded first-year team at a first-year FIRST regional.
Unread 23-06-2004, 20:58
Fold em oval!
Yes, I'm talking the FIRST-sepcific ttl port. Also, as I understand it, both the RC and the Robovation have a ttl serial port.
Team 1257
Unread 23-06-2004, 21:56
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
I can tell you more about hardware than software.
The Program port is a standard DCE RS-232 port.
To my knowledge, TTL uses an almost identical format as RS-232, the difference is that it uses different voltages. The wave forms are identical, though.
RS-232 is 1 = -3v to -25v; 0 = 3v to 25v.
TTL is (generally) 1 = 5v; 0 = 0v.
My favorite site on this is Beyond Logic, and Thier serial article.
In the RCs, the Prog port is USART1 in api, the TTL is USART2.
In the MCC18 Libraries Doc (C:\mcc18\doc\MPLAB-C18-Libraries.pdf), the API info can be found in section 2.10 (p. 58). There is probably more info on Microchip's web site, but that's down at the moment.
Unread 25-06-2004, 12:44
Gene F's Avatar
Gene F Gene F is offline
FIRST Fanatic
AKA: Gene Falendysz
#0343 (Metal in Motion)
Gene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to behold
Send a message via AIM to Gene F
Astronouth7303,
Here is the code we used to talk to a second micro that was keeping track of our position. It uses the TTL port. The documentation supplied didn't mention setting the port directio registers (See the first couple of lines in the SensorInitializePort() routine). The EDU Bot did it for you but the RC requires that you do it yourself. If you want the source files PM me and I'll email you the files.
Gene F. Team 343 Metal in Motion
AAARRRGGG!!! The tabs all got removed when I posted the code! If anyone needs/wants the actual source code PM me.
#include "ifi_aliases.h"
#include "ifi_default.h"
#include "ifi_utilities.h"
#include "sensors.h"
#include "printf_lib.h"
// Added by Gene
#include <usart.h>
#include "delays.h"
SensorPackType Sensors;
* FUNCTION NAME: InitializeSensorPort
* PURPOSE: Opens the serial port 2 for communicating with the scensors at
* 19.2k baud, 8 bits, no parity, one stop bit, and no flow control.
* CALLED FROM: user_routines.c
* ARGUMENTS: none
* RETURNS: void
void SensorInitializePort (void)
// Set up TX pin as an output and RX as an input.
TRISGbits.TRISG1 = 0;
TRISGbits.TRISG2 = 1;
Open2USART(USART_TX_INT_OFF &
USART_RX_INT_OFF &
USART_ASYNCH_MODE &
USART_EIGHT_BIT &
USART_CONT_RX &
USART_BRGH_HIGH,
128);
Delay1KTCYx( 50 ); /* Settling time */
/* Code to read Bills device. */
* FUNCTION NAME: ReadSensorPack
* PURPOSE: Talks to the sensor pack to read the current data
* ARGUMENTS: none
* RETURNS: void
void SensorPackRead (void)
int i, j;
RCSTA2bits.CREN = 1; // Re-enable the receiver
// Send an STX to the sensor pack to tell it to send the data
putc2USART(STX);
// Loop for the number of characters in the sensor pack data
for ( j = 0; j < 8/*sizeof(SensorPackType)*/; j++ )
// Wait a finite amount of time for the next character to arrive.
for ( i = 0; i < 2500; i++ )
if ( DataRdy2USART())
break;
// If a character arrived (we didn't timeout)
if ( i != 2500 )
// Grab the next charcter from the USART and place it in our data structure
Sensors.chars[j] = getc2USART();
else
// If it failed then clear any possible errors
RCSTA2bits.CREN = 0; // Disable the receiver
printf("Rx Fail DataRdy = %d\n",(int)DataRdy2USART()); /* printf EXAMPLE */
// printf("x=%6d,y=%6d,pe=%6d,dd=%4d,ae=%4d\n", Sensors.LeftOdom, Sensors.RightOdom, Sensors.PosError, (int)(unsigned char)Sensors.DDCompass, (int)( char)Sensors.AngleError );
* FUNCTION NAME: ensorEnterAutoMode
* PURPOSE: Puts the sensor pack into automatic mode sending the desired x
* and y coordiantes.
* Format of command: A<xl><xl><yl><yh>
* ARGUMENTS: none
* RETURNS: void
void SensorEnterAutoMode (int x, int y)
volatile int i;
printf("x=%d y=%d\r",x,y);
while (Busy2USART());
putc2USART('A');
for(i=0;i<1000;i++);
putc2USART((char)(x & 0xff));
putc2USART((char)((x >> 8) & 0xff));
putc2USART((char)(y & 0xff));
putc2USART((char)((y >> 8) & 0xff));
putc2USART('\0');
- Gene Falendysz
Having trouble with TTL port Gene F Programming 12 10-02-2004 15:23
TTL pins Dave... Control System 3 07-02-2004 23:59
Fried program slots? Jeff Waegelin Programming 18 19-03-2003 18:08
Dashreader.dll: A Visual Basic .NET user control to read the dashboard port Ameya Programming 4 12-01-2003 23:40
Change to Initializing Inputs and Outputs Jferrante Programming 4 07-01-2003 11:36
