Go to Post What good will it do to have 10,000 teams who barely have a clue and are just scraping by versus 2,000 teams that are actually sustainable? - Cory [more]
Unread 23-06-2004, 01:24
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Martin 20P hubless gears
I'm looking for Martin 20P gears (20* PA) like Small Parts sells (GSS part number prefix) but with NO hubs. Does Martin make these? I sure hope so because it is a pain milling or turning off the hubs. I've looked at their catalog but it is quite confusing to me. If they do make them, what is an example of a part number? I need the part number so I can get them from Motion Industries. I will need 30, 45, and 60 tooth ones. Thanks.
Unread 23-06-2004, 10:15
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Martin 20P hubless gears
Martin doesn't appear to offer 20DP 20deg PA gears in hubless versions. I've checked Browning/Emerson-EPT and they don't either. I have a few possible options:
SDP-SI offers 20DP 20deg spur gear stock. The down side is that you'll have to bore it yourself and cut it to width. The up side is that you can make the gears whatever widt you want. I used this stuff to fix a problem with stripping gears in our tranny this year.
Rush Gears appears to have what you need. I can't get prices, so you'll have to call and get a quote. If all those gears they list aren't stock, then it's quite possible that it'll be cheaper to just buy the martin gear and machine it down.
Unread 24-06-2004, 00:02
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I remember hearing that Rush Gears are extremely expensive.
I had to take the hubs off of like 12 gears and it only took me around an hour or so, so it isn't *that* big a deal.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 24-06-2004, 00:26
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
Originally Posted by Matt Reiland
Let me tell you was I ever wrong! We went to order an 80 tooth 20 pitch 20 pressure angle gear, needed it in about a week. Just to get a quote on the gear you needed to fill out all of the account paper work, took over a day to process, then the quote came back.
[gets up from floor after nearly having heart attack]
per gear the price was over $900, yes that is in hundreds, we thought they maybe screwed up the decimal place since they were under $100 every where else. Nope. I think that Rush shouldn't even be listed as a source for FIRST type robots. After a bit more searching we found that Motion Industries had them all in stock at way under $100 each and they are ready for pickup in only 2 days. I think it would be beneficial if we get together a white paper or similar listing valid sources for the different materials that teams use. It could save allot of teams allot of time.
http://www.chiefdelphi.com/forums/sh...ght=Rush+Gears
Purdue Alumni
Cummins, Inc.
Lasercutting Spur Gears? sanddrag Technical Discussion 38 20-04-2004 17:57
What type of steel are gears commonly made from? Matt Adams Technical Discussion 5 02-01-2004 23:19
Helical gears that come with new drill motor Joe P Technical Discussion 4 12-01-2003 11:09
Best source for gears? Smallparts? drivetrain advice wanted! Frank(Aflak) Technical Discussion 11 10-01-2003 17:22
Need help! What kind of gears are we allowed to use?? Randy_Ai Technical Discussion 3 23-01-2002 22:56
