Go to Post *POP!* I suppose I'll have to change my hair style to the John V-Neun now. - Billfred [more]
Unread 24-06-2004, 10:42
REVving up for a new season
FRC #2848 (All-sparks)
Re: TechnoKats 2-speed gearbox
http://home.comcast.net/~tarbell/bakergearbox.zip
there you go....remember these are solid models so you have many different options with these files. the assembly is a solid model assemby so you won;t be able to modify anything ( great for placement in a full robot cad) and the individual parts are all to spec so if you wanted a working assemby with transisions and constraints you would open all the indivual parts and put them together. also included are the parts you will have to buy or come in the kit. hope this helps some people out. let me know if anything doesn't work
Greg
Unread 24-06-2004, 12:08
ebenhopwil's Avatar
ebenhopwil ebenhopwil is offline
#0115 (MVRT)
ebenhopwil is an unknown quantity at this point
Send a message via AIM to ebenhopwil
Greg
Thanks a lot. I'll try it out.
Unread 24-06-2004, 12:23
ebenhopwil's Avatar
#0115 (MVRT)
hmm... just tried it. got the following error:
bad CRC f47c01e0 (should be e972790d)
basically winZip can't seem to extract it.
Unread 24-06-2004, 12:40
did you extract all of the files before you opened them
also you will need to open inventor and inport the files because the "open with" feature doesn;t work with this
try those solutions and if they don;t work i will probably post the files unzipped
Unread 24-06-2004, 12:59
ebenhopwil's Avatar
#0115 (MVRT)
yeah. I tried to extract all the files into a folder first, and winZip kept giving me errors.
Unread 24-06-2004, 13:14
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
I also tried it and recieved the CSC error. Something is messed up w/ the assembly folder.
Purdue Alumni
Cummins, Inc.
Unread 24-06-2004, 13:55
try this
http://home.comcast.net/~tarbell/gearbox.htm
right click and download each file individually
Unread 27-06-2004, 02:06
NotQuiteFree's Avatar
NotQuiteFree NotQuiteFree is offline
Do the WAAAAVE!!
#0957 (Watson)
NotQuiteFree will become famous soon enough
Send a message via MSN to NotQuiteFree
We used this exact gearbox on our robot this year. Wonderful design, and the machining and assembly went off without a hitch. Actually, a couple of students, myself included, are designing a gearbox for next year, and I have all the documentation for this one on my computer. I keep using it as a reference, as I have never done this before. It is an easy design to understand, and very efficient. If you were at the PNW regional, you know the torque and speed it provided us. Also, the whitepaper is excellent.
Yo.
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 26-04-2004 21:27
White Paper Discuss: 2 speed, Shift-on-the-fly TechnoKat Gearbox CD47-Bot Extra Discussion 35 23-01-2004 20:16
pic: dual speed gearbox CD47-Bot Extra Discussion 9 07-10-2003 15:04
Multi Speed Dual Motor Gearbox tenfour General Forum 14 08-09-2003 13:09
