Go to Post I'm tired of quoting the manual for today so all I will say is "Try again". - Vikesrock [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 23-06-2004, 01:18
NumberQ NumberQ is offline
AKA: Josh
#0694 (Stuy Pulse)
NumberQ is an unknown quantity at this point
Broken O/I
I have an old O/I (from a p-basic kit) And when we power it up the power led goes on green and the no data/radio goes on red. The small screen says 68.8. And thats it. It doesnt work. Dosnt comunicate with with the RC (channels are the same) doesnt respond to any input (all of the dip-switches are right) when you press the select button the 68.8 doesnt change. Its basicly dead. Now, looking at it it looks very much like a software (firmware?) issue. So, 1) does anybody know how to do a factory reset? or has anybody opened one up? Is it flashed on there? can we re-flash it?
We arent going to send it in to get repaired, cause we arent going to spend the money, so really we are willing to try anything (nothing to lose).
Any help would be GREATLY apreciated.
Unread 23-06-2004, 09:32
Pierson's Avatar
Pierson Pierson is offline
Pierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of light
Send a message via AIM to Pierson
Re: Broken O/I
Not being a programming person, I can't really help you, but I believe IFI keeps many if not most or all of the old docs on their website.
Or, you could call IFI up, explain your problem and they might have a quick fix for you. And if they say, "you'll have to send it in" just say "Thank you, we will think about it."
Pierson
Former Captain & Fundraiser of Team 360
Join in on these fun threads:
Three Worded Story
Word Association
Unread 23-06-2004, 12:27
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Broken O/I
More info would help. Did you check the fuses? Is it a 3 or 4 digit display? Does it dashboard? Does it seem to dectect the RC, but the RC not detect it?
As far as re-loading flash, I think your best bet is to open it and try to figure out out proc. is in it.
Unread 23-06-2004, 12:34
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Re: Broken O/I
i would reccommend you not to open the unit up. this will most likely cause damage from static electricity right away. What i would do is contact IFI at info@ifirobotics.com and explain your problem to them, and try to determine a year issued or model # for the email. From there they pob could send you some help or even the origional firmware package and you might beable to flash it then. Just before you open up any controllers or IFI products, contact them first, you will regret it later if you dont.
-Michael Dessingue
Unread 23-06-2004, 13:24
Bharat Nain's Avatar
Re: Broken O/I
Best possible advice, Contact Innovation FIRST. Let them handle it, its the best possible advice. Although I did open up a control system and fixed it, but its a whole lot complicated than you can think.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 24-06-2004, 15:54
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
Re: Broken O/I
If you take the O/I apart yourself and try to fix it, it will void any warrenty the part had on it and Innvation FIRST won't touch it. (I believe the O/I even has little stickers covering the screwholes on the back that say "warrenty void if broken" -- correct me if I'm wrong, I haven't looked an one in quite awhile!)
Call Innovation FIRST, see what they say.
Good luck!
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 24-06-2004, 17:13
Joshua May's Avatar
Joshua May Joshua May is offline
Go Bears!
FRC #1110 (Binary Bulldogs)
Joshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond repute
Send a message via AIM to Joshua May
Re: Broken O/I
Good luck!
They're on there.
Yeah, I wouldn't open up the OI unless IFI tells you to. Now have you tried to test if it works on tether, I assume it wouldn't though. Just contact IFI and see what they say, maybe they'll let you download the firmware.
The FIRST Wiki - openFIRST - Ultimate Robot Challenge - URC Wiki
I currently have 50 GMail invites, PM or email me for one.
UC Berkeley Class of 2009
2005 Las Vegas Regional Autodesk Visualization Award
2005 Las Vegas Regional #8 Seeded Alliance with 988 and 1505
2006 Southern California Regional #15 seed
Unread 24-06-2004, 20:56
AKA: Jamie Bliss
Re: Broken O/I
And tell us how they download firmware to the OI. That would be interesting.
Unread 30-09-2004, 20:54
jmwinston jmwinston is offline
Nina
AKA: Nina Fabiano
jmwinston is an unknown quantity at this point
Send a message via AIM to jmwinston
Re: Broken O/I
when you get a hold of the company do share with us what they tell you. you never know when one of us might need the information and be able to help someone else with the same problem.
Unread 30-09-2004, 21:17
Umm Errr...
Re: Broken O/I
In every piece of IFI equipment that i have had the opportunity to void the warranty on, I have noticed a small 5 pin .1" pinheader. I believe this to be an ICSP header. The number of pins match. ICSP is a standard interface for programming pic microcontrollers in circuit using a programming tool. I strongly believe that this is how they change the firmware. There may also be a second way of programming the OI through the serial port(dashboard) that they are not telling us about. I have not had an opportunity to take apart a 2004 OI but i'm pretty sure that when i do this is what i will find. Actually now i am curious. I wonder if they have enabled code preotection. If not it would be possible to download the firmware from the OI, disassemble it, and hack the OI to do evil things. ::devious grin::
1139 Alumni
Unread 01-10-2004, 16:06
Matt Reiland's Avatar
'The' drive behind the drive
Re: Broken O/I
Email me numberQ, I may have a spare that you can have if you need it.
Robonaut Next Generation Control System Development
2003 GLR Champions (302,67,226)
2003 Buckeye Semi-Finalists(902,494,226)
2002 Nationals QuarterFinalists
2001 West MI QuarterFinalists
2000 GLR Semi-Finalists
Tapping broken taps (a.k.a. I'm all tapped out) dlavery Technical Discussion 28 26-06-2004 22:56
"Spare Parts" Rules Are Broken Matt Adams Rules/Strategy 138 09-04-2004 12:10
What happens to the broken parts after competitions? Greg Needel General Forum 4 31-03-2003 01:46
Highest Score Record Broken Jonathan M. General Forum 1 25-03-2003 09:30
broken robots Dave_222 General Forum 0 30-01-2002 13:18
