Go to Post This is going to be leet. Or something like that. I can't wait. - Billfred [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 24-06-2004, 17:13
Joshua May's Avatar
Joshua May Joshua May is offline
Go Bears!
FRC #1110 (Binary Bulldogs)
Joshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond repute
Send a message via AIM to Joshua May
Re: Broken O/I
Originally Posted by Katie Reynolds
If you take the O/I apart yourself and try to fix it, it will void any warrenty the part had on it and Innvation FIRST won't touch it. (I believe the O/I even has little stickers covering the screwholes on the back that say "warrenty void if broken" -- correct me if I'm wrong, I haven't looked an one in quite awhile!)
Call Innovation FIRST, see what they say.
Good luck!
They're on there.
Yeah, I wouldn't open up the OI unless IFI tells you to. Now have you tried to test if it works on tether, I assume it wouldn't though. Just contact IFI and see what they say, maybe they'll let you download the firmware.
The FIRST Wiki - openFIRST - Ultimate Robot Challenge - URC Wiki
I currently have 50 GMail invites, PM or email me for one.
UC Berkeley Class of 2009
2005 Las Vegas Regional Autodesk Visualization Award
2005 Las Vegas Regional #8 Seeded Alliance with 988 and 1505
2006 Southern California Regional #15 seed
Unread 24-06-2004, 20:56
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Broken O/I
And tell us how they download firmware to the OI. That would be interesting.
Unread 30-09-2004, 20:54
jmwinston jmwinston is offline
Nina
AKA: Nina Fabiano
jmwinston is an unknown quantity at this point
Send a message via AIM to jmwinston
Re: Broken O/I
when you get a hold of the company do share with us what they tell you. you never know when one of us might need the information and be able to help someone else with the same problem.
Unread 30-09-2004, 21:17
Umm Errr...
Re: Broken O/I
In every piece of IFI equipment that i have had the opportunity to void the warranty on, I have noticed a small 5 pin .1" pinheader. I believe this to be an ICSP header. The number of pins match. ICSP is a standard interface for programming pic microcontrollers in circuit using a programming tool. I strongly believe that this is how they change the firmware. There may also be a second way of programming the OI through the serial port(dashboard) that they are not telling us about. I have not had an opportunity to take apart a 2004 OI but i'm pretty sure that when i do this is what i will find. Actually now i am curious. I wonder if they have enabled code preotection. If not it would be possible to download the firmware from the OI, disassemble it, and hack the OI to do evil things. ::devious grin::
1139 Alumni
Unread 01-10-2004, 16:06
Matt Reiland's Avatar
'The' drive behind the drive
Re: Broken O/I
Email me numberQ, I may have a spare that you can have if you need it.
Robonaut Next Generation Control System Development
2003 GLR Champions (302,67,226)
2003 Buckeye Semi-Finalists(902,494,226)
2002 Nationals QuarterFinalists
2001 West MI QuarterFinalists
2000 GLR Semi-Finalists
Tapping broken taps (a.k.a. I'm all tapped out) dlavery Technical Discussion 28 26-06-2004 22:56
"Spare Parts" Rules Are Broken Matt Adams Rules/Strategy 138 09-04-2004 12:10
What happens to the broken parts after competitions? Greg Needel General Forum 4 31-03-2003 01:46
Highest Score Record Broken Jonathan M. General Forum 1 25-03-2003 09:30
broken robots Dave_222 General Forum 0 30-01-2002 13:18
