Go to Post I normally prefer my speed controllers to brake, rather then break. - Joe Ross [more]
Unread 24-06-2004, 15:06
ThomasTuttle ThomasTuttle is offline
2004 Beantown Blitz Scorekeeper 1
#0125 (NU-TRONS)
Team Role: Student
ThomasTuttle is an unknown quantity at this point
Send a message via AIM to ThomasTuttle Send a message via MSN to ThomasTuttle Send a message via Yahoo to ThomasTuttle
Exclamation Portable BASIC Stamp- or PIC-driven Dashboard Viewer...
I am thinking about building a small device with a touch screen LCD and a Dashboard cable on it for debugging robot stuff without hauling around a laptop. I am looking at the Dashboard specs, and I'm confused about something.
In the IFI specs, they have three bytes, control A, control B, and control C, which show up in all packets. The high nybble of control A and the two high bits of control C are "moding" bits which determine the type of packet. Here is what I have so far:
RC -> OI (legacy): control A, bit 4 = 0; control C, bit 7 = 0
RC -> OI (extended): control A, bit 4 = 1; control C, bit 7 = 0
RC -> OI (status): control A, bit 4 = 1; control C, bit 7 = 1
OI -> RC: ?????
That is where I am confused; they specify no way of finding out if a packet is from the OI to the RC. Logic would dictate that control A bit 4 = 0 and control C bit 7 = 1, but it didn't say that so I'm guessing it's wrong.
Once I have this, I will release diagrams. (For those who are drooling over it, the total cost will probably be about $50, most of which I'm willing to cover since the thought of programming a PIC with a touch-screen graphic LCD attached is just too good to pass up.)
Thanks,
Thomas Tuttle, Team 125 (NU-TRONS)
Unread 24-06-2004, 20:55
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Portable BASIC Stamp- or PIC-driven Dashboard Viewer...
Your best bet is to write a VB program to display packet data, and search for what it is. You may also need look in to the Checksum bytes.
You may end up needing to look for indirect evidence; like identical bytes. (in #2, byte4=byte6 and byte7=byte9)
Unread 24-06-2004, 21:35
#0125 (NU-TRONS)
Team Role: Student
I think I figured it out... there is actually a jumper in/on the OI that selects which type of packet to return... then you just set that in the program... right?
Unread 24-06-2004, 21:38
AKA: Jamie Bliss
Right under the dashboard port. nothing in code. Nothin'. Zilch. Nada.
Impending BASIC Stamp Editor Beta 2 release Greg Ross Programming 9 19-09-2003 06:05
Auxilliary Basic Stamp Chip Kai Zhao Technical Discussion 9 07-01-2003 21:21
Firestorm Dashboard Viewer Beta 2 archiver 2000 0 23-06-2002 22:58
Firestorm Dashboard Viewer archiver 2000 0 23-06-2002 22:57
Dashboard Viewer Khalicl13 Technical Discussion 8 15-06-2001 23:36
