Go to Post Did you know that if a G7, G27, G28, and G20 occur in that order at the same time, then the referee will appear to be doing the "YMCA"? :) - Jack Jones [more]
Go Back   Chief Delphi > Other > FIRST-related Organizations
View Poll Results: What engine should we use? (See post)
Crystal Space 15 35.71%
Genesis3D 4 9.52%
Unreal 21 50.00%
Torque 2 4.76%
Voters: 42. You may not vote on this poll
  #31   Spotlight this post!
Unread 21-06-2004, 00:45
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: [FVG]: Choosing an Engine: Final Poll
Both Unreal 2 and 1 are being discussed in this post, I think its important to know some distinctions.
First of all, Unreal 1 is dying. There is no development to the engine and most modding has come to a halt.
Though Unreal 1 would mean that the game would almost definitley be playable on most systems, that isn't because it can go lower than Unreal 2 in terms of graphics, but because it can't go as high. It is definitley possible to use Unreal 2 with the same level of detail (texture resolution, poly count, lighting mode....) as an Unreal 1 game and achieve similar performance.
Unreal 2 has built in support for vehicles and is much more able to handle non-human moving stuff. It is much easier to script the movements neccesary for a robot. Actually, I don't think U1 would even be able to do the job at all.
Team 1257
  #32   Spotlight this post!
Unread 21-06-2004, 03:40
Denman's Avatar
Denman Denman is offline
Tie Wrap-Not Cable Tie or Zip tie
AKA: Stephen Denman
FRC #0759 (Systemetric)
Denman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud of
Send a message via ICQ to Denman Send a message via AIM to Denman Send a message via MSN to Denman Send a message via Yahoo to Denman
unrealED is free with any copy of ut, i think. I have it from my original ut and i think i have it for the latest one, but i havn't actually looked, you can probably find it for download somewhere, as games companies tend to support modders now as it makes them look good etc....
I am an ex-member of team 759.
759: regional winners with 522 and 233 NYC (2004)
FIRSTWiki.org - Contribute, learn, inspire.
"Teach the way of the GP and the way of the GP shall teach you" - Me
  #33   Spotlight this post!
Unread 21-06-2004, 15:47
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
You can actually download the runtime for Unreal2. But you can't get to the API reference w/o registering.
  #34   Spotlight this post!
Unread 22-06-2004, 15:45
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Ok, so what do you say we choose the engine now?
Obviously, Unreal has the majority...
But I don't like it...
  #35   Spotlight this post!
Unread 22-06-2004, 16:11
AKA: Jamie Bliss
We need to establish some goals. Specifically, why are we (you) doing this?
  1. because some dude suggested it and someone coerced me to help
  2. because I'm bored
  3. Because it'd be pimp and I'd be shamed to make it bad.
The list goes on. I happen to lean towards #3; I'd prefer CS.
  #36   Spotlight this post!
Unread 22-06-2004, 16:44
Programming User
Originally Posted by Astronouth7303
We need to establish some goals. Specifically, why?
Um... ok...
The main reason I'm against Unreal is because of it not being open source, and its cost... But, if we end up using it, I'll get over it.
  #37   Spotlight this post!
Unread 23-06-2004, 18:43
Nastay's Avatar
Nastay Nastay is offline
Jim Smith
AKA: Jim Smith
#0236 (Techno Ticks)
Nastay is an unknown quantity at this point
Send a message via AIM to Nastay
I would much prefer Crystal Space, because it is open source, free and is compatible with other OSs(Unix, Linux, MacOSX...).
Unreal is compatible with MacOSX, but its not open source, and it will not give us a stand alone game, this means that not only does our target audience have to be a FIRST addict (or someone looking into FIRST) but they would also have to own a $50 game....
Crystal Space
First Video Game! - Port Leader
sudo rm -r -f -v /
Nastay
21
  #38   Spotlight this post!
Unread 25-06-2004, 01:56
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Does Dave think it'd be pimp?
*ducks* Sorry... couldn't resist.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
  #39   Spotlight this post!
Unread 25-06-2004, 09:47
Joshua May's Avatar
Joshua May Joshua May is offline
Go Bears!
FRC #1110 (Binary Bulldogs)
Joshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond repute
Send a message via AIM to Joshua May
Dave would definitely think it is pimp, and so do I.
Crystal Space is the way to go, it's Open Source (which I think we would have to have for SourceForge) and we can make a standalone with it.
The FIRST Wiki - openFIRST - Ultimate Robot Challenge - URC Wiki
I currently have 50 GMail invites, PM or email me for one.
UC Berkeley Class of 2009
2005 Las Vegas Regional Autodesk Visualization Award
2005 Las Vegas Regional #8 Seeded Alliance with 988 and 1505
2006 Southern California Regional #15 seed
  #40   Spotlight this post!
Unread 25-06-2004, 12:24
Programming User
So, I'm thinking that CS is our choice. Agree, Astronouth?
  #41   Spotlight this post!
Unread 27-06-2004, 07:52
AKA: Jamie Bliss
Thumbs up Re: [FVG]: Choosing an Engine: Final Poll
I would, yes.
Unreal would be the choice if we wanted to make it look absolutely pristine, but didn't care about licensing, $$$, or ability to distribute. CrystalSpace, however, is open source, has an open license, and is pretty good on the quality.
  #42   Spotlight this post!
Unread 30-06-2004, 16:10
CJO's Avatar
CJO CJO is offline
Emeritus Pain in the $@#$@#$@#
AKA: Christopher J. O'Connell
None #1097 (Site 3 Engineering)
CJO will become famous soon enoughCJO will become famous soon enough
Mission Plan ?!?
Well, I wrote out a really long thread, which somehow hasn't made it up yet, so, here in a nutshell is what I said:
  1. Don't bite off more than you can chew: specifically, you need to write a program that can incorporate new robots and playing fields regularly.
  2. FIRST has a successful structure because it attempts to create a partnership between corporations and students.
  3. Get Epic to assist in this endevour to build FVG
    1. Don't ask for too much, instead, ask for them to help you make a FVG based on the Unreal engine.
    2. This proposed FVG would not be playable as anything but FVG, and would not be moddable except to add bots.
    3. Epic would get lots of good press, and you would get a spectacular game engione
  4. Finally, you would be the people not who failed to build a FIRST game, again, but who moved the paradigm of the FIRST architecture into a whole new field.
Team 1097 -- Site 3 Engineering
2003 Sacramento Rookie All Star
2003 Silicon Valley Rookie All Star
2004 Sacramento Engineering Inspiration Award
2004 Sacramento Visualization Award
2004 Outstanding Volunteer Award (G. Glasser)
2004 Silicon Valley Sportsmanship Award
2004 National Visualization Runner Up
2004 Cal Games Finalist
2005 Sacramento Sportsmanship Award
2005 Sacramento #1 seed
2005 Sacramento Finalist
2005 Silicon Valley Sportsmanship Award
2005 Silicon Valley #1 Seed
2005 Silicon Valley Finalist
  #43   Spotlight this post!
Unread 02-07-2004, 19:17
Mike Ciance Mike Ciance is offline
FRC #0025 (Raider Robotix)
Mike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant future
Send a message via AIM to Mike Ciance
Re: Mission Plan ?!?
i'm not the expert on programming, but crystal space sounds more efficent to me. doesnt unreal cost a ton? will they be willing to fully sponsor us?
  #44   Spotlight this post!
Unread 04-07-2004, 14:18
AKA: Jamie Bliss
That would be if we actually got the Unreal2 engine. It was been suggested to make an unreal mod or use quake. (also be epic)
If some one can get Epic to sponsor this, I am more than willing to use Unreal. But until then, I'm going to support CrystalSpace.
  #45   Spotlight this post!
Unread 05-07-2004, 11:17
Heretic121 Heretic121 is offline
The Resident Gamer -
AKA: Pat or Harry... if you ask its a long story...
FRC #0078 (AIR Strike)
Team Role: Tactician
Heretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond repute
Send a message via AIM to Heretic121
well... i was just looking around my UT2k4 clan site and i cam upon this... i haven't d/l'ed it, but it does seem like its a proggy where you enter in numbers, and you get a finished file/s that start you to your mod... but from what ive seen if we ever did get an unreal2 engine thingy (where we buy it or they give one to us) that it can be transfered over from there...
http://udn.epicgames.com/Two/PublicModResource
2004 - Team 121 Human Player
2005 - Team 121 Student Captian
2006 - Team 38 Drive Team Coach / Mentor
2007 - 2009 - Team 121 Mentor / Strategery Master
2010 - 2013 - Team 78 Mentor / Strategy / Scouting Lead
2014 - Team 78 coach
FIRST Video Game: Choosing an engine Astronouth7303 FIRST-related Organizations 11 16-06-2004 22:48
