Go to Post They knew that the number of gracious, professional, make-your-grandmother-so-proud-she-will-puke moments of exemplary behavior by the teams would far outshine any minor mistakes or incidents of less-than-perfect decorum. - dlavery [more]
Unread 25-06-2004, 12:44
Gene F's Avatar
Gene F Gene F is offline
FIRST Fanatic
AKA: Gene Falendysz
#0343 (Metal in Motion)
Gene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to behold
Send a message via AIM to Gene F
Re: Using the TTL port
Astronouth7303,
Here is the code we used to talk to a second micro that was keeping track of our position. It uses the TTL port. The documentation supplied didn't mention setting the port directio registers (See the first couple of lines in the SensorInitializePort() routine). The EDU Bot did it for you but the RC requires that you do it yourself. If you want the source files PM me and I'll email you the files.
Gene F. Team 343 Metal in Motion
AAARRRGGG!!! The tabs all got removed when I posted the code! If anyone needs/wants the actual source code PM me.
#include "ifi_aliases.h"
#include "ifi_default.h"
#include "ifi_utilities.h"
#include "sensors.h"
#include "printf_lib.h"
// Added by Gene
#include <usart.h>
#include "delays.h"
SensorPackType Sensors;
* FUNCTION NAME: InitializeSensorPort
* PURPOSE: Opens the serial port 2 for communicating with the scensors at
* 19.2k baud, 8 bits, no parity, one stop bit, and no flow control.
* CALLED FROM: user_routines.c
* ARGUMENTS: none
* RETURNS: void
void SensorInitializePort (void)
// Set up TX pin as an output and RX as an input.
TRISGbits.TRISG1 = 0;
TRISGbits.TRISG2 = 1;
Open2USART(USART_TX_INT_OFF &
USART_RX_INT_OFF &
USART_ASYNCH_MODE &
USART_EIGHT_BIT &
USART_CONT_RX &
USART_BRGH_HIGH,
128);
Delay1KTCYx( 50 ); /* Settling time */
/* Code to read Bills device. */
* FUNCTION NAME: ReadSensorPack
* PURPOSE: Talks to the sensor pack to read the current data
* ARGUMENTS: none
* RETURNS: void
void SensorPackRead (void)
int i, j;
RCSTA2bits.CREN = 1; // Re-enable the receiver
// Send an STX to the sensor pack to tell it to send the data
putc2USART(STX);
// Loop for the number of characters in the sensor pack data
for ( j = 0; j < 8/*sizeof(SensorPackType)*/; j++ )
// Wait a finite amount of time for the next character to arrive.
for ( i = 0; i < 2500; i++ )
if ( DataRdy2USART())
break;
// If a character arrived (we didn't timeout)
if ( i != 2500 )
// Grab the next charcter from the USART and place it in our data structure
Sensors.chars[j] = getc2USART();
else
// If it failed then clear any possible errors
RCSTA2bits.CREN = 0; // Disable the receiver
printf("Rx Fail DataRdy = %d\n",(int)DataRdy2USART()); /* printf EXAMPLE */
// printf("x=%6d,y=%6d,pe=%6d,dd=%4d,ae=%4d\n", Sensors.LeftOdom, Sensors.RightOdom, Sensors.PosError, (int)(unsigned char)Sensors.DDCompass, (int)( char)Sensors.AngleError );
* FUNCTION NAME: ensorEnterAutoMode
* PURPOSE: Puts the sensor pack into automatic mode sending the desired x
* and y coordiantes.
* Format of command: A<xl><xl><yl><yh>
* ARGUMENTS: none
* RETURNS: void
void SensorEnterAutoMode (int x, int y)
volatile int i;
printf("x=%d y=%d\r",x,y);
while (Busy2USART());
putc2USART('A');
for(i=0;i<1000;i++);
putc2USART((char)(x & 0xff));
putc2USART((char)((x >> 8) & 0xff));
putc2USART((char)(y & 0xff));
putc2USART((char)((y >> 8) & 0xff));
putc2USART('\0');
- Gene Falendysz
Having trouble with TTL port Gene F Programming 12 10-02-2004 15:23
TTL pins Dave... Control System 3 07-02-2004 23:59
Fried program slots? Jeff Waegelin Programming 18 19-03-2003 18:08
Dashreader.dll: A Visual Basic .NET user control to read the dashboard port Ameya Programming 4 12-01-2003 23:40
Change to Initializing Inputs and Outputs Jferrante Programming 4 07-01-2003 11:36
