Go to Post You want to be treated like a professional, so you need to continue to act like one even if the odds are against you. - Eugenia Gabrielov [more]
Unread 27-04-2004, 16:26
xxmaddjxx's Avatar
xxmaddjxx xxmaddjxx is offline
Captain & Driver
AKA: Mark Fisher
#1396 (Pyrobots)
Team Role: Driver
xxmaddjxx is on a distinguished road
Helical Gears in Inventor 8
having a lot of trouble constraining the helical gears that came in the vkop. trying to put together the FIRST Drivetrain, how do i constrain one on top of the other, and how do i get a motion constraint on em for them to turn correctly. any help would be appreciated
"The One Day Wonder"
2004 - Nationals Judges Award
2004 - NYC Regional Rookie Allstar
2004 - NYC Regional Semi-Finalist
Unread 21-06-2004, 19:20
patTeam241 patTeam241 is offline
College Student
AKA: Pat Cleary
patTeam241 will become famous soon enoughpatTeam241 will become famous soon enough
Send a message via AIM to patTeam241
Re: Helical Gears in Inventor 8
Where can I get the file? I think I can figure it out if I can use the file.
Unread 22-06-2004, 13:39
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
I think your problem is that the gears are modeled with the wrong helix angle. To correct this, open the gear .ipt file, right-click the Coil in the browser and select Edit Feature. On the Coil Size tab, replace the text in the Revolution field with: d2 / ( 3.142 ul * d0 ) This makes the helix angle = the face width/ pi * gear diameter (shame Inventor doesn't understand "pi").
You can constrain two gears' teeth with a tangent constraint to correctly locate them. I don't know if that constraint will hold up when you rotate the gears or not. (call it an "exercize left for the readers" ... hee hee ...)
I'd attach the corrected gear files, but they're over the limit (534K zipped).
Pete Kieselbach
Unread 25-06-2004, 16:38
xxmaddjxx's Avatar
Captain & Driver
AKA: Mark Fisher
#1396 (Pyrobots)
Team Role: Driver
thank you very much.. i dont have much time to play around in inventor anymore but il definately give it a shot!
its giving me a "Cannot modify the library file...." error
how do it get around it
Unread 26-06-2004, 00:04
Daniel Brim's Avatar
Daniel Brim Daniel Brim is offline
It's hard hat time here in Boston
AKA: DFB
FRC #0125 (NUTRONS)
Daniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond repute
Send a message via AIM to Daniel Brim
The file is in your library. Move the file into your workgroup and then you should be able to edit it.
-Daniel
2003 (2002) - 2006 -- Team 294, Beach Cities Robotics
2007 (2006) - Present -- Team 125, NUTRONS
helical gears Max Lobovsky Technical Discussion 10 16-04-2004 22:48
helical gear info mickjagger Technical Discussion 4 02-02-2003 10:16
Helical gear help Gui Cavalcanti Technical Discussion 1 27-01-2003 16:20
Helical gears that come with new drill motor Joe P Technical Discussion 4 12-01-2003 11:09
helical gears efficency Andrew Dahl Technical Discussion 0 07-01-2003 13:02
