Go to Post they used the same random number generator we used for our autonomous drive code . . . (oops did I say that?) - MrForbes [more]
Go Back   Chief Delphi > Technical > IT / Communications
  #38   Spotlight this post!
Unread 27-06-2004, 09:32
Andrew Andrew is offline
Andrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to all
Re: Using Linux?
I just got a new laptop with Windoze XP Pro pre-installed. I installed Mandrake 9.2 as a dual boot.
At the partitioning step, I chose the "use free space on windoze partition" option, selected the new size of the windoze partition, and let 'er rip. At the final step, where you can review your installed services, etc. I went into the boot-loader options and selected the windoze option as the primary boot option. You might have to hunt around to find this option. Otherwise the linux will boot first.
If you don't find this option and you boot into linux, you can edit the /etc/lilo.conf file and select another boot option. If you're not expert enough to know what I'm talking about here, you might want to cleanly install linux and fool around before going for the dual boot.
Inside linux there's a "dual boot howto" which explains all this better.
In any event, my Windoze XP and my Mandrake 9.2 linux are co-existing peacefully on the same machine now.
Linux SteveC116 3D Animation and Competition 22 25-03-2004 15:07
Linux: steps to program fullsize RC robot rwaliany Programming 31 14-02-2004 14:45
Linux And Windows XP Raven_Writer Chit-Chat 4 06-08-2003 18:53
RoboEmu for Linux (PBASIC emulator) rbayer Programming 5 21-11-2002 21:08
Linux file extensions rbayer CD Forum Support 5 14-11-2002 23:04
