Go to Post We had an over all losing record this year. When I look at kid's faces, they don't give a rip about that. I see excitement about the next event and talking about improvements for next year. Winning is nice, but that is not the reason I do what I do. - wilsonmw04 [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 26-06-2004, 19:54
Venkatesh Venkatesh is offline
FRC #0030
Venkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to behold
E-Mail Server
Hwello,
I have been trying to set up an E-Mail system for my domain for some time, and each attempt has been only vaguely successful.
My first version was a very crude assembly which only worked when the moon was in a correct phase. It consisted of a Java program, which was activated by incoming SMTP connections. It just pretended to pay attention to the incoming email, but did nothing to the incoming data. This was because I don't know how to do file I/O in Java. Meanwhile, I had a packet sniffer (snort) running as well. When the Java program was activated, snort started recording all incoming data. Finally a perl script mutilated the logs to make email from it. This system could only receive email, but it was a start.
Version two is my current setup. Im running the Postcast SMTP (Free) Server. The server is only meant to be an outbound machine, but it can receive emails, if it is instructed to not automatically forward email. However I have to VNC into the server (a windows 2000 machine) to read my email, which is inconvenient. And, Postcast doesn't have POP3 support, so no email client here.
For some time, I have been trying EzMTS. I have been unable to send email outbound, but I can receive email and use Outlook to read it and all that. I tried it with the SMTP Server and POP3 server components running. I still can't get outbound to work, so I am leaving that setup dormant.
So now I call for help. Do any of you know of any good email server systems (SMTP and POP3/IMAP)? And can any of you help me set one up? I have had no luck with sendmail on windows.
Thanks
-- vs, me@acm.jhu.edu
Mentor, Team 1719, 2007
Team 30, 2002-2005
Unread 26-06-2004, 20:02
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: E-Mail Server
Well, if you are using windows, the ideal thing is Exchange. I don't mean to hurt the open-source zealot in you, but its the truth, Exchange offers lots of really powerful features. If you can't get a copy for a reasonable price, then I think you are gonna have to settle for pretty bad stuff. I tried setting up a windows email server a while ago too and had a lot of trouble finding quality software. If i rememebr correctly, Imail wasn't too bad (www.ipswitch.com). Anyway, good luck.
Team 1257
Unread 26-06-2004, 20:28
Timothy D. Ginn's Avatar
Timothy D. Ginn Timothy D. Ginn is offline
I check here maybe once a year.
Timothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to all
Send a message via ICQ to Timothy D. Ginn Send a message via AIM to Timothy D. Ginn Send a message via MSN to Timothy D. Ginn Send a message via Yahoo to Timothy D. Ginn
Re: E-Mail Server
I remember that 4 or 5 years ago (when I actually used Windows as a desktop OS) there was a piece of mail software called ArgoSoft Mail Server. It was pretty simple, and supported a number of protocols (including POP and SMTP).
I remember it was convenient for my experiments back then, because it stored all the messages as a separate text file and created a folder for each inbox, so I could create mail by placing text files in directories. I don't know if ArgoSoft still exists, but it was free and not bad at all (well, for a personal mail server, which is what it sounds like you're looking for).
Now I use sendmail and exim (but I'm unsure as to whether or not there's Windows versions of either of those).
Alumni of FRC Team 1006
Former mentor of Full Lego Alchemist (FLL 5621) - Sempar School / Computing Students' Association of Queen's University
Unread 27-06-2004, 07:33
FRC #0030
Re: E-Mail Server
I have tried ArGoSoft Mail Server. For unknown reasons, it will not accept any mail at all. It drops all inbound mail, while logging that it is doing so.
And btw, I have wanted to try exchange, but Exchange = $$$. That is what keeps me from it. I use only 100% Legal software here.
Team 30, 2002-2005
Unread 27-06-2004, 12:37
Re: E-Mail Server
I'll see if I can set it up on a box downstairs that basically just sits there waiting for me to want to test things like this and let you know what happens (if I get the same issue).
Unread 27-06-2004, 12:55
Re: E-Mail Server
I think I know why it was dropping the mail (and more imporantly, how to fix it):
In ArgoSoft Mail Server, go to:
Tools - Options - Local Domains
Add all of the domains on your machine to that list, and click OK
For example, localhost, computername, as well as full DNS names like mail.example.org.
In the General tab, you probably also want to enable "Allow Relay" so that you can send messages to other domains (if you enable relaying, it's also a good idea to turn on SMTP authentication in the SMTP authentication tab).
Also, make sure that you've created the users in: Tools - Users.
Unread 27-06-2004, 15:43
FRC #0030
Re: E-Mail Server
Thanks,
When I had last used Argosoft, I had not set the local domains correctly. I had set that to be my local computer's name (Inferno), not the publically accessible address (endeavour.zapto.org).
Team 30, 2002-2005
Unread 27-06-2004, 23:56
Pierson's Avatar
Pierson Pierson is offline
Pierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of light
Send a message via AIM to Pierson
Re: E-Mail Server
I think the above post might say that you are finished... but this is what I posted to a similar question about web and mail servers: http://www.chiefdelphi.com/forums/sh...054#post269054
I use ClarkConnect it is a Linux (RedHat based) distro and will do web, mail, ftp, etc... it is very easy to use, free, and has a great support forum!
Pierson
Former Captain & Fundraiser of Team 360
Join in on these fun threads:
Three Worded Story
Word Association
Unread 26-06-2005, 12:05
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Re: E-Mail Server
I found this post so I didn't restart a new one. I am running a webserver and want to get an email server/program running. A guy I am working with and I are designing a website which reequires reservations sent out via email to the sender and to the owner. I am running argosoft and it works well but the problem is that it wont run as a service. So I am looking for a new program either very inexpensive ($10) or legally free like argosoft. All this is running on a dual 2GHz server running win 2003 server and connected via sDSL. If anyone has any suggestions or ideas please post them.
-Mike
mike-site
Unread 26-06-2005, 14:11
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
Re: E-Mail Server
-Mike
mike-site
Doesn't IIS have some mail services built in? Never used them, because the only time I've ever used windows for mail is with exchange, but something to look into.
Unread 26-06-2005, 14:26
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: E-Mail Server
I'm not exactly sure how capable of an e-mail server you need but I run a very reliable e-mail server on a 16 MHz Macintosh SE/30 with a 40 mb hard drive and 16mb of RAM. It is Eudora Internet Mail Server. Hasn't failed me yet!
Unread 26-06-2005, 17:21
Pierson's Avatar
Re: E-Mail Server
Try the Mercury mail server from Pegasus. It is free and it is a mail server. http://www.pmail.com
Pierson
Three Worded Story
Word Association
Unread 26-06-2005, 17:49
JonBell JonBell is offline
None #0546 (Technotics)
JonBell is just really niceJonBell is just really niceJonBell is just really niceJonBell is just really niceJonBell is just really nice
Send a message via AIM to JonBell
Re: E-Mail Server
Ever thought about running linux (perhaps even CentOs or Debian)?
I run a small cluster of about 5 linux machines with Qmail and courier. Very nice. Both are free, of course.
If you are thinking of outsourcing your email, feel free to drop us a line - we are having a hosting blowout atm.
Unread 27-06-2005, 01:34
Mike AA's Avatar
AKA: Mike Aalderink
Re: E-Mail Server
IIS does have it but when I tried using it for some reason it didn't want to work, plus IIS messes up my apache sometimes. I'm kinda staying away from windows stuff other than the OS.
from what I'm seeing it costs $40? or did you find a link for a free version?
I once tried installing Linux on one of my other computers and for some reason it didn't want to install I think it was video card issues. I have somewhere one of the more recent versions of Linux I just don't have another computer to test an install and config on. I would like to do so soon though.
Thanks for the offer on the outsourcing, I think I'll pass for now. Too expensive for now. Maybe if I get more business in the future.
-Mike
Unread 27-06-2005, 01:38
Re: E-Mail Server
The older versions of EIMS are available for free at ftp.eudora.com I spend about $40 on the machine it runs on though.
There is a port of Debian made for Motorola 68K processors which means you can run it on an old Macintosh like an SE/30 or LC III or something of the sort. Just thought I'd throw that out there if anyone ever wants to try it.
You can also run NetBSD and the whole slew of compatible stuff like Apache and PHP on one of these inexpensive and reliable machines. http://mark.is-a-geek.org
Anyone else having trouble with Yahoo mail services? Elgin Clock IT / Communications 12 20-03-2004 16:59
How has the new server treated us? Brandon Martus CD Forum Support 12 07-12-2002 00:16
Pic Block (save server space) Jack CD Forum Support 3 22-09-2002 01:05
FTP server with FlashFXP Jeff Rodriguez Chit-Chat 2 24-08-2002 11:28
free chat server archiver 2000 2 23-06-2002 22:08
