Go to Post You know you are a true tech geek when you end up on top of the Sears tower, and the only pictures you post are the ones of the radio antennae. ;) - Tom Line [more]
Unread 27-06-2004, 13:41
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: And you thought you had cool omni-wheels
I've been having a hard time proving this, but I believe this is the way both holonomic systems work:
efficiency as compared with wheels facing forward
100% speed
100% power output
1/sqrt(2) max force (obviously, at stall)
It is pretty clear that force is 1/sqrt(2) because when the robot is pushing against something fixed, the force vector that the motor is creating is 45deg to the direction force is being applied.
The other two claims aren't as simple. The only way I can attempt to prove them is through conservation of energy stuff, when I try to look at force vectors, they don't make sense.
Anyway, assuming lossless omniwheels (no friction in lateral movement), 100% of power output goes in the forward direction. Even though there should be a force vector perpendicular to direction of movement, it does not use any energy because it the lateral movement is lossless. If power output is constant, speed must be also constant because max speed is is just the point where ffriction(v) = fmotor(v). (I think equivalent holonomic and straight wheels systems would require different gearing, though, because even if wheels are same sized, a revolution of a straight wheel covers further linear distance than what at 45deg)
Team 1257
You know you're from Wisconsin when ... Katie Reynolds Chit-Chat 9 22-06-2004 22:09
Battle Cry 157#1Driver Off-Season Events 37 14-06-2003 05:43
Favorite Michael Jackson Song Mullet Chit-Chat 7 13-02-2003 20:39
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
