Go to Post by the way when someone calles me a dork or geek, i tell them to look up dork and geek in the dictionary, and that i would rather be called nerd :) - Mike Schroeder [more]
Unread 29-06-2004, 15:46
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
team 33 tranny info
just wondering if team 33 was planning or has already published information about their transmission from this season. hopefully a whitepaper is coming soon, but in the meantime i'd love some decent pictures and a little description. thanks.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 29-06-2004, 16:39
Paul H's Avatar
Paul H Paul H is offline
Renegade of Funk
AKA: Paul Huston
FRC #0033 (Killer Bees)
Paul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant future
Send a message via AIM to Paul H
Re: team 33 tranny info
I'll see Jim next tuesday and see what he's doing with the whitepaper. It's not out yet. I'll try to get some closeups at IRI
This page has some info on it.
Random tidbits that I can think of:
-It's obviously 2 two speed trannies in series
-It's made with a lathe and a mill....or a drill press with a moving table.
-The gears are heat treated pinion rod. We turned them down on the lathe and had them heat treated.
-Yes, the gears will be fine if you heat treat them, and we filed the edges a bit just to be safe. You wouldn't want to use this method if you were designing a transmission for a go kart or something, but for the amount of time a robot is used, it should be fine. We went to three regionals, nationals, and will attend 3 offseasons.
-The side panels are polycarbonate of some sort
-That is actually a big version of the tranny in the picture. It can be compressed down to roughly half the size by staggering the shafts rather than having them in a straight line.
-The automation code uses a shaft encoder that is actually in the transmission, but our demo used banner sensors. Same concept, it bases the shifting on the output RPM.
-There is obviously no motor matching in it, we used #35 chain to match the speeds of the drill gearboxes in low and chips, exactly like the martians (494) did in 2003, and put the output into the transmission
-The transmissions can be mounted between the wheels
-The motor pan/mounts weighed about a pound, it was a folded sheet of aluminum.
-You can also make a rock solid, feather light 2 speed transmission with this method, just build half of it.
Here's something I threw together in Paint, it would be our robot's drivetrain this year if it wasn't for the climbing system.
-Paul
Unread 29-06-2004, 16:42
Paul H's Avatar
Renegade of Funk
AKA: Paul Huston
Just looked at that picture again. Obviously, the slave chain between the wheels would have to clear above and below the transmission in the above view, I don't know what I was thinking.
Also, the motor reduction occurs after the transmission. Rather than building it in, we just reduce it between the transmission and the wheel by putting a big sprocket on the wheel and a small one in the transmission (obviously)
-Paul
Unread 30-06-2004, 18:04
AKA: Anthony Lapp
thanks for the info.....i talked with jim on several occassions about the tranny, but what i'd really love are some decent pictures. i may be ar iri, but if i'm not please take some basic photos of the gear switching components and post them for me. thanks again.
Anthony Lapp
RobotOpen
Unread 02-07-2004, 03:06
Billfred's Avatar
Billfred Billfred is offline
I'm just thinking out loud...
According to my sources, 33's version had the tranny shift on the fly, complete with shift points and everything.
Given that our programming department is sorely lacking, wouldn't it be possible to set up a bump-shifting setup and get World Rally on things? Just set up a switch and a small shifter a driver could nudge with a free hand.
(And count me on the list of people awaiting this white paper. This might just be the next killer app in FIRST.)
Unread 02-07-2004, 13:53
AKA: Anthony Lapp
actually the demo version of the tranny was setup as a sequential style gearbox. clicking the trigger advanced one gear up, another click went another gear up and so on, then the thumb would walk you back down. obviously this can get hectic on the field so an automatic shift scheduler was used to take the burden of the drivers.
Anthony Lapp
RobotOpen
Unread 03-07-2004, 13:53
Paul H's Avatar
Renegade of Funk
AKA: Paul Huston
Yeah, you could do the bump shifting, but one reason that the whitepaper isn't out yet is because Jim es working on making a totally generic code. He will distribute the code with the whitepaper, so everyone who builds the transmission can have it automated if they choose.
I'll get pictures at IRI.
-Paul
Unread 03-07-2004, 14:02
Joshua May's Avatar
Joshua May Joshua May is offline
Go Bears!
FRC #1110 (Binary Bulldogs)
Joshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond repute
Send a message via AIM to Joshua May
Awesome, you guys are too much.
The FIRST Wiki - openFIRST - Ultimate Robot Challenge - URC Wiki
I currently have 50 GMail invites, PM or email me for one.
UC Berkeley Class of 2009
2005 Las Vegas Regional Autodesk Visualization Award
2005 Las Vegas Regional #8 Seeded Alliance with 988 and 1505
2006 Southern California Regional #15 seed
Unread 03-07-2004, 14:10
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
where did you guys buy the pinion rod for the gears?
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 03-07-2004, 14:44
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I'm guessing SDP but they may have gotten it locally.
Unread 03-07-2004, 19:02
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
I went to the killer bees booth at least three or four times to watch their demo box, and sent everyone from my team to see it at least once. Here are some of my impressions:
* Shifting is extremely smooth. They would rev up the gearbox, hit a button and it changed in the blink of an eye.
* Very, very, consistent! I never once saw it malfunction in the slightest. I've heard of issues with other trannies ripping gears apart or freezing up, but this is truly a shift on the fly design.
* Four speeds is probably overkill for most applications, and they weren't using four in their (very successful) robot. The two speed served them very well.
See the FIRSTwiki entry! As soon as this whitepaper goes up I plan to wiki it with a vengence (Copyright permitting, naturally).
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 03-07-2004, 19:52
Paul H's Avatar
Renegade of Funk
AKA: Paul Huston
I'll ask about the whitepaper and where we got the pinion rod Tuesday at our IRI practice. I'm also going to try to get a video of the demo board shifting and put it online.
-Paul
Unread 05-07-2004, 23:33
AKA: Anthony Lapp
the pinion wire is from Mcmaster
Anthony Lapp
RobotOpen
Unread 06-07-2004, 01:14
RogerR's Avatar
AKA: Roger Riquelme
i read in the original post (by d. lavery) about this transmission that they used 16 DP gears. in addition, i've read (and seen) that they use pinion rod/wire. i've been looking for 16 DP pinion rod/wire for almost a year, and i was persuaded that it didn't exist, until i found out about the 33 transmission. now i'm starting to think i was mixed up. was i wrong? are ya'll using 16 DP gears?
Unread 06-07-2004, 01:42
I don't know what they are using since I've never seen it in person but McMaster does sell 16P spur gear stock. Check the bottom of this page Quite a limited tooth count selection though.
Am I the only person with this job? A. Leese General Forum 55 22-06-2006 20:10
**FIRST EMAIL**/Important Information for All Championship Teams! Jeremy Roberts FIRST E-Mail Blast Archive 0 09-04-2004 21:12
UTC Scrimmage Info? Andy Grady General Forum 13 21-02-2004 08:30
The 2003 Index of team's post about their robot... Ken Leung Robot Showcase 4 28-02-2003 00:18
Disqualifications archiver 1999 13 23-06-2002 21:53
