Go to Post And then since this is GTR-W there's also maple syrup somewhere and the drive team says "Sooory." - PayneTrain [more]
Unread 29-06-2004, 22:50
FizMan's Avatar
FizMan FizMan is offline
aboot, eh?
AKA: Chris Sinclair
#0783 (Mobotics)
FizMan will become famous soon enough
Send a message via AIM to FizMan Send a message via MSN to FizMan
Turning; easier one way or the other?
Working on a possible design for next year, I was just curious aboot which way is easier to steer:
1) The wheels on the 24" sides
2) The wheels on the 30" sides
This is with tank steering, so one set runs backwards, the other goes forwards.
My logic tells me that having the wheels 30" apart (instead of 24") means that they'll produce a greater turning force (torque) around the axis of rotation (the centre of the bot). So I just want a bit of confirmation on that.
Joules per second! Watt? Joules per second! Watt? Jouls per second! Watt?
Unread 29-06-2004, 22:52
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: Turning; easier one way or the other?
I'm guessing you mean all 4 wheels are going to be the driving wheels?
For example, no castors in the front or back of the robot?
Unread 29-06-2004, 22:57
Ben Lauer's Avatar
Ben Lauer Ben Lauer is offline
Seshambeh Dareh Meyod
Ben Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond repute
There are some good White Paper on Drive systems..and one explains the physics behind tank drive...check them out, and you will get more that you asked for!!! in a good way oh course
Unread 29-06-2004, 22:59
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Yep.
Chris Hibner created a GREAT whitepaper which very simply lays out the physics behind drivetrain turning. Check it out.
Props to Chris.
JV
Unread 30-06-2004, 00:05
Ryan F.'s Avatar
Ryan F. Ryan F. is offline
Ryan F. is a jewel in the roughRyan F. is a jewel in the roughRyan F. is a jewel in the rough
For the basics, wheels on the 24 side will have much easier turning than the 30..because of their distance apart. This can make a big difference based on the wheels your using. If you plan on using pneumatic wheels like the ones provided in the kit, your best off going with 24. Even that isn't too great. We did tests with different wheels on a robot this year, and were barely able to turn with those the 24" way. All they did were skip, and eat up our battery.
Unread 30-06-2004, 00:14
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Definitely make your robot wider than it is long if you want it to turn well.
Unread 30-06-2004, 00:15
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
sorry, but aren't the dimensions 30 by 36, not 24 by 30?
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Unread 30-06-2004, 01:46
Ryan F.'s Avatar
*slaps head*..yes...it's too late for me to notice such an insignificant detail
Unread 30-06-2004, 07:34
FizMan's Avatar
aboot, eh?
AKA: Chris Sinclair
#0783 (Mobotics)
......... so that's why everyone's bot seemed so much bigger than ours... just kidding.
Well see, I figured since most of you were in the states (in Canada myself), I had to take the exchange rate into account.
But yeah, all four wheels are driving. And what I'm doing is developing a crab drive for the robot, so I can choose which wheels turn the robot, so depending on how we build the robot, we can make the software choose to orientate the wheels to turn either with the front/back or the side wheels.
Unread 30-06-2004, 07:44
Solace's Avatar
AKA: Jake
putting the wheels on the 30" side makes the robot turn earsier nd be more controllable
...What is a man,
Jake
Team Paragon #571
Unread 02-07-2004, 17:21
Pat Roche Pat Roche is offline
Mechanical Engineer
FRC #0134 (Team Discovery)
Pat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to behold
Send a message via AIM to Pat Roche
Just for reference, when doing track drive as long as your distance between you tracks is longer than the length of your track touching the ground then you will turn well(assuming that your tracks have good traction and do not slip alot). I believe this same principle applies to wheels also....correct me if Im wrong.
-Pat
Team Discovery #134 Alumni 1999-2004
Division by Zero #229 Alumni 2004-2009
Team Discovery again?
2010 and Beyond
Where have the last 11 years have gone?
Unread 02-07-2004, 18:51
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
You aren't wrong, but I believe FizMan was talking about a "crab drive". In that case, I'm not sure why you care much about tank steering because you can just turn your wheels to turn like a real car, or even cooler, move by translation by having all the wheels have the same orientation relative to the robot and changing that orientation.
Team 1257
Unread 03-07-2004, 10:34
FizMan's Avatar
aboot, eh?
AKA: Chris Sinclair
#0783 (Mobotics)
I wish Max, I wish. Unfortunately, the way I'm developing the drive, that's not possible. But the benefit of the crab drive is, assuming the game won't demand it much, we won't need to turn often.
Unread 03-07-2004, 13:47
Fold em oval!
FizMan, That sounds like you are talking about translating, not turning. How would you move in more than one dimension without turning? By translating, I mean point all 4 wheels in the direction you want to go, and drive.
Team 1257
Unread 03-07-2004, 14:03
FizMan's Avatar
aboot, eh?
AKA: Chris Sinclair
#0783 (Mobotics)
Oh yes, we are translating for the most part. BUT... unless the game is beyond my scope of comprehension, I'm going to assume that being able to TURN the robot as well will be undoubtably required... (for example, orientating the robot so that your bar hanging hook is pointed in the right direction)
Making your robot drive easier ufa_mike Control System 32 28-04-2004 21:35
Inertial Navigation and Robot Turning phrontist General Forum 2 01-04-2004 22:14
Swerve/crab drive and tank turning activemx Technical Discussion 9 23-02-2004 18:26
Balance while turning? sanddrag Dean Kamen's Inventions 8 26-09-2003 17:18
What's easier? Last year or this year? archiver 2001 2 23-06-2002 23:33
