Go to Post ...regardless of anything that happens, there should be no booing at competitions, only cheers. True, many of us want to win, but in the end, all of us are working to expand FIRST and to promote the inspiration and recognition of science and technology through gracious professionalism. - Aignam [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 30-06-2004, 00:30
Ryan F.'s Avatar
Ryan F. Ryan F. is offline
Ryan F. is a jewel in the roughRyan F. is a jewel in the roughRyan F. is a jewel in the rough
Remote Network
Okay, here it is. A friend and I are trying to set up a remote network where we can have totall remote control of each-others computers whenever we want. I'm not sure if this is possible, so I'm hoping one of you might know. We tried working with microsoft netmeeting, and had no luck there. I have DSL, and he has cable. We both run PC's with windows XP. Anyone know how to do this, or it it's possible. Help will be appreciated [subliminal message] somehow rewarded [subliminal message].
Unread 30-06-2004, 00:39
REVving up for a new season
FRC #2848 (All-sparks)
Re: Remote Network
just set up remote desktop connections on both
this should take you step by step
http://www.microsoft.com/windowsxp/u...p_03may16.mspx
Unread 30-06-2004, 01:01
Stefan's Avatar
Stefan Stefan is offline
FRC #1002 (The CircuitRunners)
Stefan is on a distinguished road
Send a message via AIM to Stefan
Re: Remote Network
Or if you dont have XP pro on both use VNC which is similar to Remote Desktop. You will need to install it as a service and set up passwords.
VNC is avaible at
http://www.realvnc.com
http://www.tightvnc.com
Member of RoboJackets
-- GT Aerospace Major
-- Alumni - FRC No. 1002 CircuitRunners (03 - 05)
Unread 30-06-2004, 01:06
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Re: Remote Network
From what i have learned and think, RDC in XP Pro only work with computers that are on the same LAN.
-Michael Dessingue
Unread 30-06-2004, 01:09
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
Re: Remote Network
My friends and I do this for "virtual LAN parties." What you want is a Virtual Private Network. Google it!
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 30-06-2004, 01:15
evulish's Avatar
evulish evulish is offline
1010100
AKA: Grant Harding
#0084 (WATTNESS (bot: Chuck))
evulish is just really niceevulish is just really niceevulish is just really niceevulish is just really nice
Send a message via AIM to evulish
Re: Remote Network
Yeah, set up a VPN and use RDC. That's what I use and it's pretty nice. You'll need XP Pro on all the machines that you want to access. XP Home won't work.
I'm a professional web developer. I'm good with PHP, Perl, Java/JSP, some RoR, XML, Javascript (AJAX as well), (x)HTML, CSS, etc.. Validated code is good; fully cross-browser code is better (you comply to your users and the software they use, not the other way around. Sorry!)
Unread 30-06-2004, 01:35
Stefan's Avatar
Re: Remote Network
nah the computers dont have to be on the same lan but u need to config ur routers to make it work. I do it all the time after school from school to my home comp during the school year. Note XP home can act like a client for Remote desktop.
Unread 30-06-2004, 02:17
Pierson's Avatar
Pierson Pierson is offline
Pierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of light
Send a message via AIM to Pierson
Re: Remote Network
Make sure that you set up your router to do port forwarding. You will need to assign a static local ip address to your computer and then just tell the router what port to forward and to where. Microsoft Terminal Services communicates over ports 3389, 4194, and 1604. The default is 3389. (Then mirror this configuration on both your network and your friends)
The easy part is now done... Then you need to think about how you will "call" the other person. The easy part is opening up the Remote Desktop Connection... But you will need to find your global ip. If you are lucky, you will have a static ip. If you are not lucky it will be dynamic. To find your ip, go to a site like this: http://www.whatismyip.com/ Then you and your friend can swap ip's over an IM session or you can go the further step of setting up a domain name.
Also, you both need to run win xp pro to do remote desktop sharing. However as mentioned above you can use VNC the process is similar but the port numbers are different.
Feel free to pm me if you have more questions. I have done set-ups like this for clients and they seem to like it!
Pierson
Former Captain & Fundraiser of Team 360
Join in on these fun threads:
Three Worded Story
Word Association
Unread 30-06-2004, 12:36
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Thumbs up Re: Remote Network
I reccomend if you have xp home, split the cost of getting XP Pro, then use remote desktop, very easy to setup and you can get versions of XP pro for $100 (white box). I bought my verson through www.tigerdirect.com I am unsure if its still on there.
Unread 30-06-2004, 13:13
Ryan F.'s Avatar
Re: Remote Network
Thanks for all your help. We're trying to set it up using XP's remote desktop. Both of us have XP home edition, but on
http://www.microsoft.com/windowsxp/...up_03may16.mspx we were able to find a free download of the remote desktop. We haven't finished setting it up right now, but we should in the next couple of days.
Unread 30-06-2004, 15:33
Pierson's Avatar
Re: Remote Network
Though I can't be sure because the link doesn't work, I highly doubt this will work. I believe you are downloading the client and not server portion of the Remote Desktop Protocol (RDP) Therefore, I would try VNC if I were you, http://www.realvnc.com/
Pierson
Three Worded Story
Word Association
Unread 30-06-2004, 20:25
Marc P. Marc P. is offline
I fix stuff.
AKA: βetamarc
Marc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond repute
Send a message via AIM to Marc P.
Re: Remote Network
I'll second the recommendation for realvnc. I used to use remote desktop connection, but now use VNC. I've found the following:
1) Only XP Pro can serve as a host for RDC. While Home edition can serve as a client to connect to an RDC, it can not accept incoming connections. RealVNC is platform independant, and can be hosted on linux, windows (any version). There's even a mac port.
2) An RDC connection will interrupt the local user's session, and lock them out of the computer for the duration of the connection, e.g. only one of you can use the computer at any given time. A VNC connection can allow both to use the desktop simultaneously (useful for collaboration).
3) Either VNC or RDC can be used outside of a LAN. For RDC, forward port 3389 in your router to the local IP of your host machine. I'm pretty sure the default port for VNC is 5901, but I believe it's configurable to whatever you like.
4) I'd definitely recommend using a VPN to connect to each other. A VPN is relatively easy to configure, and I'd be happy to send directions to anyone who'd like them on how to configure a basic VPN within windows XP. (Even XP Home can accept incoming VPN connections).
I've set up quite a few remote desktop solutions for clients at work. RDC is convenient if you'd like to access your home computer while away, but for most other purposes I'd definitely recommend VNC. The URL again is http://www.realvnc.com.
Unread 01-07-2004, 15:06
Ryan F.'s Avatar
Re: Remote Network
Thanks for the help. We ran into the problems that you told me with remote desktop connection, so I'm now going to try VNC.
Remote Program Execution in Visual Basic Jeff Waegelin Programming 6 14-06-2004 21:15
how do i tell to the edurc when the remote is on. Code\\Pilot Programming 4 28-01-2004 21:00
Qotw [11-17-02]: Manchester or remote kickoff... Ken Leung Rumor Mill 19 09-01-2004 16:18
Remote Remote Kick off at University High School George1902 Off-Season Events 4 04-01-2004 21:05
FIRST Remote Kickoff is coming... Rich Wong General Forum 13 20-08-2003 00:00
