Go to Post >wears zebra pants >calls people weird - PayneTrain [more]
Unread 30-06-2004, 07:34
FizMan's Avatar
FizMan FizMan is offline
aboot, eh?
AKA: Chris Sinclair
#0783 (Mobotics)
FizMan will become famous soon enough
Send a message via AIM to FizMan Send a message via MSN to FizMan
Re: Turning; easier one way or the other?
......... so that's why everyone's bot seemed so much bigger than ours... just kidding.
Well see, I figured since most of you were in the states (in Canada myself), I had to take the exchange rate into account.
But yeah, all four wheels are driving. And what I'm doing is developing a crab drive for the robot, so I can choose which wheels turn the robot, so depending on how we build the robot, we can make the software choose to orientate the wheels to turn either with the front/back or the side wheels.
Joules per second! Watt? Joules per second! Watt? Jouls per second! Watt?
Unread 30-06-2004, 07:44
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
putting the wheels on the 30" side makes the robot turn earsier nd be more controllable
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Unread 02-07-2004, 17:21
Pat Roche Pat Roche is offline
Mechanical Engineer
FRC #0134 (Team Discovery)
Pat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to behold
Send a message via AIM to Pat Roche
Just for reference, when doing track drive as long as your distance between you tracks is longer than the length of your track touching the ground then you will turn well(assuming that your tracks have good traction and do not slip alot). I believe this same principle applies to wheels also....correct me if Im wrong.
-Pat
Team Discovery #134 Alumni 1999-2004
Division by Zero #229 Alumni 2004-2009
Team Discovery again?
2010 and Beyond
Where have the last 11 years have gone?
Unread 02-07-2004, 18:51
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
You aren't wrong, but I believe FizMan was talking about a "crab drive". In that case, I'm not sure why you care much about tank steering because you can just turn your wheels to turn like a real car, or even cooler, move by translation by having all the wheels have the same orientation relative to the robot and changing that orientation.
Team 1257
Unread 03-07-2004, 10:34
FizMan's Avatar
aboot, eh?
AKA: Chris Sinclair
#0783 (Mobotics)
I wish Max, I wish. Unfortunately, the way I'm developing the drive, that's not possible. But the benefit of the crab drive is, assuming the game won't demand it much, we won't need to turn often.
Unread 03-07-2004, 13:47
Fold em oval!
FizMan, That sounds like you are talking about translating, not turning. How would you move in more than one dimension without turning? By translating, I mean point all 4 wheels in the direction you want to go, and drive.
Team 1257
Unread 03-07-2004, 14:03
FizMan's Avatar
aboot, eh?
AKA: Chris Sinclair
#0783 (Mobotics)
Oh yes, we are translating for the most part. BUT... unless the game is beyond my scope of comprehension, I'm going to assume that being able to TURN the robot as well will be undoubtably required... (for example, orientating the robot so that your bar hanging hook is pointed in the right direction)
Making your robot drive easier ufa_mike Control System 32 28-04-2004 21:35
Inertial Navigation and Robot Turning phrontist General Forum 2 01-04-2004 22:14
Swerve/crab drive and tank turning activemx Technical Discussion 9 23-02-2004 18:26
Balance while turning? sanddrag Dean Kamen's Inventions 8 26-09-2003 17:18
What's easier? Last year or this year? archiver 2001 2 23-06-2002 23:33
