Re: Gears in Inventor
Thank you all for your help. I don't actually plan on using it to make my own gears, but I'm just a nut when it comes to precision and accuracy in anything like this I create. Again, thanks for all your help and I'll get back to you on how it worked out.
Here are some gears for the downloading.
http://www.cbliss.com/inventor/Parts/PowerTransmission/ Martin Spur Gears 169 sizes 14.5 and 20 degree Pressure angle http://www.cbliss.com/inventor/Parts...Spur Gears.zip I have downloaded the gears from the link above and they seemed to work great for me. All the gears in our transmission are from Martin. But I found this link after I had already created gears. Phil Dolan from Autodesk told me about the link, I also noticed Dez mentioned it. The best thing you can do is find a spec sheet on the gears you need to create! Last edited by team222badbrad : 30-06-2004 at 11:57. Reason: Corrected link |
| Helical Gears in Inventor 8 | xxmaddjxx | Inventor | 4 | 26-06-2004 00:04 |
| 12 in. Wheel in Inventor 7 | petek | Inventor | 1 | 17-01-2004 17:53 |
| Autodesk Inventor Award 2002 | Digo | Inventor | 1 | 24-03-2002 12:07 |
| How do i make gears in inventor? | mnkysp6353 | Inventor | 1 | 16-01-2002 02:31 |
| Inventor and Virtual Kit of Parts | Torchin | Inventor | 1 | 09-01-2002 09:59 |
