Go to Post If you are content with where you are, you have celebrated the right things. If not, perhaps it is time to reconsider... what’s most important to you. - StephLee [more]
Unread 02-07-2004, 18:51
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: Turning; easier one way or the other?
You aren't wrong, but I believe FizMan was talking about a "crab drive". In that case, I'm not sure why you care much about tank steering because you can just turn your wheels to turn like a real car, or even cooler, move by translation by having all the wheels have the same orientation relative to the robot and changing that orientation.
Team 1257
Unread 03-07-2004, 10:34
FizMan's Avatar
FizMan FizMan is offline
aboot, eh?
AKA: Chris Sinclair
#0783 (Mobotics)
FizMan will become famous soon enough
Send a message via AIM to FizMan Send a message via MSN to FizMan
I wish Max, I wish. Unfortunately, the way I'm developing the drive, that's not possible. But the benefit of the crab drive is, assuming the game won't demand it much, we won't need to turn often.
Joules per second! Watt? Joules per second! Watt? Jouls per second! Watt?
Unread 03-07-2004, 13:47
Fold em oval!
FizMan, That sounds like you are talking about translating, not turning. How would you move in more than one dimension without turning? By translating, I mean point all 4 wheels in the direction you want to go, and drive.
Team 1257
Unread 03-07-2004, 14:03
FizMan's Avatar
aboot, eh?
AKA: Chris Sinclair
#0783 (Mobotics)
Oh yes, we are translating for the most part. BUT... unless the game is beyond my scope of comprehension, I'm going to assume that being able to TURN the robot as well will be undoubtably required... (for example, orientating the robot so that your bar hanging hook is pointed in the right direction)
Making your robot drive easier ufa_mike Control System 32 28-04-2004 21:35
Inertial Navigation and Robot Turning phrontist General Forum 2 01-04-2004 22:14
Swerve/crab drive and tank turning activemx Technical Discussion 9 23-02-2004 18:26
Balance while turning? sanddrag Dean Kamen's Inventions 8 26-09-2003 17:18
What's easier? Last year or this year? archiver 2001 2 23-06-2002 23:33
