Go to Post You don't have to build a robot to be on a robot team. This isn't about the robot, it's about learning. - engunneer [more]
Go Back   Chief Delphi > Technical > IT / Communications
  #34   Spotlight this post!
Unread 04-07-2004, 17:35
Timothy D. Ginn's Avatar
Timothy D. Ginn Timothy D. Ginn is offline
I check here maybe once a year.
Timothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to all
Send a message via ICQ to Timothy D. Ginn Send a message via AIM to Timothy D. Ginn Send a message via MSN to Timothy D. Ginn Send a message via Yahoo to Timothy D. Ginn
Re: Using Linux?
Originally Posted by Astronouth7303
Yes. Linux requires 2 new file systems (neither Win32 or NTFS). I use the Hard drive backup utility in Nero. It does a sector copy to CD-Rs. The advantage is that even the partition table and MBR is preserved. The down side is that you have to restore the whole thing and you don't have access to individual files. Good for backing windows up before installing Linux.
Well, requires isn't exactly true. There is, for example, a version of Slackware called Zipslack that will run off of Windows FAT partitions. I'm sure there are other distributions with this capability. Other distributions can do the same, with more or less effort. However, yes, the regular installation procedure is to create a native Linux file system of some kind, and most installers create a swap partition (however, if you already have a Windows partition, it's possible to share the Windows swap file, rather than creating a new parition to do the same thing). One example of a free sector by sector copying tool is dd (if Nero is not available). dd is almost certainly contained on all of the Live CD distributions.
Alumni of FRC Team 1006
Former mentor of Full Lego Alchemist (FLL 5621) - Sempar School / Computing Students' Association of Queen's University
Linux SteveC116 3D Animation and Competition 22 25-03-2004 15:07
Linux: steps to program fullsize RC robot rwaliany Programming 31 14-02-2004 14:45
Linux And Windows XP Raven_Writer Chit-Chat 4 06-08-2003 18:53
RoboEmu for Linux (PBASIC emulator) rbayer Programming 5 21-11-2002 21:08
Linux file extensions rbayer CD Forum Support 5 14-11-2002 23:04
